good soldering iron for recapping motherboard
  • trickyjames
    • Jun 2005
    i have a compaq evo and it will not post there are 3 smaller caps that are bulging next to the pci slots where can i get the smaller kind i only order from mouser i need 1000uf 6.3volts can anyone find me the part number and also i need to know a good soldering iron for this job like how many watts any particular brand and what kind of tips
  • bushytails
    Moderator
    • Dec 2004
    • 217
    Re: good soldering iron for recapping motherboard
    You need to learn to use punctuation, too.
    As to some of the other questions, check the FAQ.
    --Randy
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • Geeker007
      Friend messed up my laptop motherboard while working on my bench
      by Geeker007
      Hi All,
      So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
      So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
      I have not tried putting...
      06-16-2025, 01:40 PM
    • glovecaps
      Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
      by glovecaps
      I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
      My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
      The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
      11-25-2024, 04:23 PM
    • tony359
      Kaiweets USB soldering iron
      by tony359
      I am testing a USB powered soldering iron. It's made by Kaiweets but I believe it's also sold under other names.
      As a standard test, I checked whether there was any voltage leak from the tip - that said the thing runs on USB-C power delivery so am I correct that the whole unit is floating and not grounded? If I check, I measure 90V at the tip but I have a feeling that that is not relevant? Maybe caused by that capacitor between primary and secondary inside the PSU? I do not see current flowing at all.
      In other words, do you think it's expected and...
      02-06-2024, 12:51 PM
    • Archimedes
      HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
      by Archimedes
      Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
      Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
      Fans are spinning. Blindly could install windows11 and got the device manager...
      07-30-2024, 05:14 PM
