Miida Digipet-60 converter 160
  • ccm347
    • Dec 2008
    I have a Miida Digipet-60 with a 160 converter frequency counter. I can't find any information this unit. I really need a schematic diagram. Does any one know where I could locate a manual or schematic?
  • ngml
    Repair of an LG split AC system indoor unit PCB
    by ngml
    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
    This indicates an error in the communication between the outdoor and the indoor unit.
    The outdoor unit is fine, so the problem is the indoor PCB.
    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
    Does anybody have the schematics of this board,...
    02-01-2025, 12:55 PM
  • gabri2211
    I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
    by gabri2211
    hello everyone, I'm looking for the wiring diagram of this led monitor.
    the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
    I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
    I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
    thanks to those who will answer
    12-10-2024, 04:37 PM
  • nobbnobb1
    Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
    by nobbnobb1
    Hi guys,
    Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
    When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
    02-03-2022, 11:14 AM
    MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
    The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
    Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
    10-23-2024, 03:23 AM
  • gizmo1990
    What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
    by gizmo1990
    I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
    The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
    10-21-2024, 08:02 AM
