Cheapy 862D+ Rework Station
  • jazzie366
    • May 2016
    • 304
    I've got one of these things, and it's seen some HEAVY usage, this thing has been my daily driver for awhile now, and I have to say I love it.
    However, I had to mod it to make it better.
    The air gun was nowhere near as good as Hakko, nor Weller. So I found out you can get replacement elements that are much better. 7$ for a hotter element and this thing performs exactly like a Hakko, much nicer.
    Now, my biggest complaint is the soldering iron. The included tips are, to be nice, shit. Use them on high heat like I do, and they'll fall apart in a few months. Where can I get good pencil tips that don't fit loosely on the end and won't deteriorate? I know people say Hakko tips will work, but which ones?
    If anyone could point me in the right direction, that'd be great.
    Also, recommend me some good desoldering wick, I can't stand the Radioshack shit, it doesn't work at all.
    Popcorn.
  • cadsulfide
    • Aug 2014
    • 3
    Re: Cheapy 862D+ Rework Station
    Chemtronics for solderwick...like Kestor for solder...it just works well
    • Mario
      • Sep 2007
      • 64
      I believe most of them use a hakko 936 compatible soldering iron tip
      • shahnld
        wds-580 rework station issue
        by shahnld
        Good day.
        i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
        Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
        kind regards...
        03-28-2024, 01:14 PM
      • minimania
        Need Schematic for jbc am6800 rework station
        by minimania
        hi all im looking for a Schematic for jbc am6800 rework station
        mine has stopped working fully
        it started with turning off when switched on then after a few off and ons it worked sort of for awhile
        now it wont turn on at all...
        01-28-2025, 03:44 PM
      • shahnld
        Seamark ZM-R6200 Rework station
        by shahnld
        Good day Experts.
        I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
        Kind regards
        01-24-2024, 10:55 AM
      • petemanuk
        Help with IR6500 rework station
        by petemanuk
        I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
        1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
        2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
        10-14-2022, 12:31 AM
      • liquidzorch
        862D+ solder station iron out of control when fan on
        by liquidzorch
        Hello.
        I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
        First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
        06-09-2022, 08:49 PM
