Need software for Intelligent universal programmer lk48
  • JLatter
    replied
    Re: Need software for Intelligent universal programmer lk48
    You need to edit the program exe with the above offsets, then you are up and running again.
    replied
    which software?
  • kilavuz
    replied
    Hi Guys
    After i updatet program my licence not working any more. Any help to get it work again ?
    Thansk
  • JLatter
    replied
    Yeah - I changed my PC and don't have a LPT port anymore, so it was neccesary
    To those who need XP version. 0x0043ef10
    Can't test, but should work.
    replied
    you did the usb version? NICE!
  • JLatter
    replied
    Version 13.30 - Win10
    UXP - offset 0x003D640 from 0x55 to 0xC3
  • megaraider
    replied
    For the challenge sake, I do like reverse engineering, I've extracted all files from the installations files.
    Files:
    1. 'LT**UXP_1320_WIN7.exe', and
    2. ‘LT**UXP_1320_WIN10.exe'.
    Summary:
    Extracted files are pretty much similar, 285 files in total, except for 8 different files and 8 files found only in the W10 version.
    The most unexpected(?) and interesting detail is the W10 version still includes all files for the parallel port version (including the drivers)!
    See full details in attached files.
    Advantage:
    Anyone willing to force the parallel port version in 64 bits OS has everything needed to complete the task.
    Conclusion:
    This outcome although unexpected, raises questions about true practical value:
    Can't even remember the last time I saw a Laptop with parallel port (well… unless I turn around and look at my shelf. There is a couple, all in full working condition).
    On desktop computers parallel port is gradually disappearing…!
    On the other hand, old desktop computers with parallel port don't have enough resources to run W7 64 bits or newer.
    Thus we end up with 3 exceptions:
    1. Recent desktop computer, with parallel port, running W7 64 bits or newer;
    2. Old desktop computer running a lite (very, very lite) Wx 64 bits OS version;
    3. Using a mini-ITX embedded dedicated motherboard (e.g.: ASRock J4125B-ITX);
    Therefore, facing the unlikeness of any of those exceptions, I leave it up to anyone willingness…
    Reminder:
    No USB to parallel port converter will work with the parallel port universal programmer version.
    This has nothing to do with the converter brand, model, etc.! Rather the (almost) nonexistent data buffer!
    [In fact, to avoid buffer underrun they use a very nasty (outrageous) trick:
    - triggering a high priority interrupt continuously.
    Anyone using it ought to have seen the outcome: while performing any programming task the computer (almost) freezes.
  • megaraider
    replied
    Re: xp48 programmer
    Originally posted by Per Hansson View Post
    Threads merged
  • Per Hansson
    replied
    Re: xp48 programmer
    Originally posted by megaraider View Post
    imo it would be more helpful if you move your post to the 'original' thread.
    Threads merged
  • megaraider
    replied
    Re: xp48 programmer
    Yes the drivers are embedded in the installation file, but here's 2 ideas:
    - use the well known install shield unpacking tools (to be concise look here) (didn't check if mention unshield ).
    { cab files are 49536328 ISc( signature; CAB, HDR; Install Shield v5.x or 6.x compressed file }
    - Install the installation file but don't close the last dialog! First take a look under folders:
    \user\current\AppData\Local\Temp\{F4B3F755-2E4E-46BF-A27D-2AF95FC6FD01}\{53CE7A2F-3A57-40BE-9AC6-0E331CA6AC96}
    C\Windows\system32\Drivers\LTKP*.sys
    ALL drivers are there
    Last step:
    Put the drivers on their right places and register them.
    replied
    Re: xp48 programmer
    installing on 32bit or just manually unpacking the installer is a step,
    but the real problem is the jungo driver is embeded in the exe.
    you need to unpack it or corrupt it in some way.
    or maybe replace it if the newer one is smaller.
    but i doubt it's smaller.
  • megaraider
    replied
    Re: xp48 programmer
    Originally posted by stj View Post
    it does explain that arguement we had over wether they had removed the parallel port version or not.
    i was unpacking it with win7 64bit and you obviously had the last decent o.s. m$ ever made
    Yes it does clears it up
    Took a look at their site and they do mention:
    Parallel port: Windows 2000 / XP / Vista(32bit) / 7(32bit) / 8.1(32bit) / 10(32bit)
    USB port: Windows 2000 / XP / Vista(32bit) / 7 / 8.1 / 10
    and the same sh1t at license page.
    Those bastards charge a fortune for the software license and yet they don't want to pay JUNGO for a one time fee to use newer version (latest 16.10).
    They're still stuck with version v5.0.5 released in 2002!!!
    only a mod can do that.
    imho overwriting *.sys files with a licensed newer jungo version might do the trick... (plus writing the ...\Labt00l-**XP folder from a supported win 32 bit version installation).
    Alas i don't even know if only the last step is need (not tested) providing you also copy & paste the *.sys files to the %windir%\system32\drivers\ folder.
    P.S.: I'm still thinking these should be moved to the 'original thread' where it'll be more helpful...!
    replied
    Re: xp48 programmer
  • megaraider
    replied
    Re: xp48 programmer
    just read some interesting shit at the makers site,
    with the latest software releases you MUST use win-XP and it MUST be 32bit or the installer wont install the parrallel port software.
    if your on Vista or newer and/or running 64bit it will ONLY install the UXP usb-port software version!
    i suspect it's because they use a 3rd party parrallel port driver from jungo.
    Thanks, good to know.
    replied
    xp48 programmer
  • mgaloi1970
    replied
    Originally posted by Skybug2 View Post
    did you manage to find a valid license file or a patch to use the software Labtool uxp or dataman?
    thanks
  • megaraider
    replied
    o.k. i have other problems then, fucking windows is screwing around.
    Just a hint: try installing previous versions and watch the behavior. If problem persist then it's, most likely, win screwing around.
    replied
    i'll take notes and open a thread for it
  • megaraider
    replied
    i did, i'm getting a 12gig file that only installs 1 folder with a usb icon.
    LT**UXP_1300_WIN7.exe (CRC-32: 567212F4)
    Installed folders ...\Labt00l-**UXP, and ...\Labt00l-**XP:
    See screen capture files attached.
    replied
