How to fill in VIA?
  • cfox10
    • Sep 2015
    • 5
    How to fill in VIA?
    I'm currently repairing a damaged amplifier board and was trying to figure out the best method for filling the VIA from where the MOSFET came off of.
    Any help would be appreciated.. I've searched and searched.. pictures would be great as well if anyone has any examples.
    • 31009
    Re: How to fill in VIA?
    you mean you ripped out the through-hole plating?
    • cfox10
      • Sep 2015
      • 5
      This amp has been worked on previously before I got it. Appears it will need them filled/fixed.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        Assuming it's just a double-sided board, then it's easy.
        For the two outer legs, the top side pad doesn't go anywhere, so ignore it. For the center leg, if the pad is ripped, scrape some of the soldermask off with a sharp blade (I find a scalpel works very well) next to it on the land and make a solder bridge from the lead to the freshly exposed copper. You can also add a piece of wire to help.
        For the bottom side the same applies. If the center lead has connections on both sides of the board you will need to reconnect on both sides. For the outer two legs it seems they only connect on the bottom.
        To clear any blocked holes, I would fill them with fresh solder, then holding the board sideways, hold a desolder pump on one side and your iron on the other side of the filled hole. Heat the solder until liquid and then wait a couple seconds more, hit the desolder pump button as you remove the iron, the hole should be cleared easily.
        Use the iron on whichever side of the hole has the largest track\plane to heat it more effectively.
        -David VanHorn
        • cfox10
          • Sep 2015
          • 5
          I found this method. Sounds kind of like what you're stating.. scrape back some copper from the trace and solder a wire to it/fill the hole with the wire.
          I'm going to for the easiest/cleanest looking method I can. Don't want it looking odd as it's covered by plexiglass showing off the internals of the amp lol
          • Agent24
            I see dead caps
            • Oct 2007
            • 4951
            • New Zealand
            Don't use the exact method in that photo then. Besides looking horrible, that wire is quite thin compared to the original pad and may cause some kind of performance issues or such.
            I was thinking of a much shorter, and thicker piece of wire, just enough to go between the transistor leg and the land\track immediately next to it.
            I'll try to find or take a photo that shows my idea better.
            -David VanHorn
            • cfox10
              • Sep 2015
              • 5
              If you could find or take a photo that would be great. I've never actually ran into this issue before, wish it was something I was taught. We had this conductive epoxy stuff that we used to fill the holes with.. I can't find it anywhere, and I'm not sure it'd work in this case anyway.
              • MrCommunistGen
                Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                by MrCommunistGen
                My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                07-12-2021, 05:11 PM
              • jinu_j
                How to test Subwoofer Amplifier with only a multimeter
                by jinu_j
                Hi Folks
                Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                Problem
                I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                Any advice would be appreciated...
                08-29-2024, 02:05 AM
              • UserXP
                Mackie CR4 amplifier no sound
                by UserXP
                Hi, people.
                I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                10-17-2020, 05:06 PM
              • Francesc V.
                Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                by Francesc V.
                Hi:
                I've realized that one of the channels of this amplifier has no proper sound.
                This is the signal at the speakers output.
                As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                07-15-2025, 01:33 AM
              • waspie
                Aiwa GX-770 Amplifier Protection Circuit
                by waspie
                I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                11-29-2022, 09:58 AM
