I need to desolder a bridge rectifier as shown on the attached photos. I found that two of the four holes are different from the other two holes. The middle two holes have something like a metal ring on the hole. Is there any reason for this? When desoldering, is special technique and/or equipment needed?
Any special techniques in desoldering this rectifier?
Tags: None
If you have a temperature controlled heat gun and a temperature controlled soldering iron preheat the center two pins and use new 60/40 soldering wick with flux on it and use the heat gun on the round metal insert then use the soldering iron on the other side with the soldering wick but do not put the soldering wick on it until the solder is flowing then use the wick and it should flow to the wick
If you have a desoldering gun you basically do it the same way but instead of using the wick you use the desoldering gun now if you have a desoldering sucking pump iron is a little bit easier to use than just the pump pinComment
Thanks for your suggestions.If you have a temperature controlled heat gun and a temperature controlled soldering iron preheat the center two pins and use new 60/40 soldering wick with flux on it and use the heat gun on the round metal insert then use the soldering iron on the other side with the soldering wick but do not put the soldering wick on it until the solder is flowing then use the wick and it should flow to the wick
Yes, it is difficult to do so with just a soldering iron and soldering wick. Finally, I used a heat gun to desolder it.Comment
On one layer board is not so hard, see video on 15min about technique with tin sucker, and after tin river technique to desolder multileg component. Soldering wick I dont use on these easy thing because it costs and THT components have a lot tin on pads.
https://m.youtube.com/watch?v=s1MY5de8vXc
This specification for the MSI Gaming GE62 6QD-243RU Apache Pro Heroes Special Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE62 6QD-243RU Apache Pro Heroes Special Edition boardview and GE62 6QD-243RU Apache Pro Heroes Special Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 05:30 AM
This specification for the MSI Gaming GE62 6QD-452FR Apache Pro Heroes Special Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE62 6QD-452FR Apache Pro Heroes Special Edition boardview and GE62 6QD-452FR Apache Pro Heroes Special Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 05:30 AM
This specification for the MSI Gaming GE62 6QD-269XES Apache Pro Heroes Special Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE62 6QD-269XES Apache Pro Heroes Special Edition boardview and GE62 6QD-269XES Apache Pro Heroes Special Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the...09-06-2024, 05:30 AM
This specification for the MSI Gaming GE62 6QD-225IT Apache Pro Heroes Special Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE62 6QD-225IT Apache Pro Heroes Special Edition boardview and GE62 6QD-225IT Apache Pro Heroes Special Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 05:30 AM
This specification for the MSI Gaming GE62 6QD Apache Pro Heroes Special Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE62 6QD Apache Pro Heroes Special Edition boardview and GE62 6QD Apache Pro Heroes Special Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....09-06-2024, 05:30 AM
- Loading...
