LCD protective film for meters?
  • Guido
    • Oct 2006
    • 8
    Hello every one I am new here and need a little help.
    I am looking for the proper lens protective film to put on my test equipment lenses.
    I have checked Google and Ebay and there seems to be several types on the market.
    Hoping some one here has experience with this and can save me the pain of trial and error.
    Guido
    TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
    FF Series (Very Fast Acting), 0603 Size
    Features
    ● Very fast acting at 200% overload current levels
    ● Low DCR
    ● High inrush current withstanding capability
    ● Fiberglass enforced epoxy fuse body
    ● Copper termination with nickel and tin plating
    ● Halogen free, RoHS compliance and lead-free
    Applications
    ● Notebook computers and tablets
    ● Digital cameras
    ● Memory cards
    ● Toys
    ● Bluetooth earphones
    ● Portable electronic devices​...
    10-07-2024, 05:50 AM
  • WatchItFool
    Sony FVS1000 film scanner telecine Roms
    by WatchItFool
    looking for ROM files / updates, software, and CAD files. Everything really
    i have most, but not all, available documentation by sony pn.
    What was all listed in the sony pro reference library?
    I dont know of any places to look. will anyone name names?
    08-04-2023, 12:58 AM
  • jkruns
    M1 A2338 screen and touchbar issues after cleaning up liquid damage
    by jkruns
    This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
    My patient is an A2338 Macbook Pro M1 (late 2020).
    It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
    04-22-2024, 06:45 AM
  • H...
    HP Victus 16-e0185ax backlight
    by H...
    At first, backlight would be really sensitive, sometimes you have to apply pressure to the bottom left of screen for backlight to be on, sometimes it will stay on but if desk is bumped it will go off. Eventually it stopped all together, disconnected battery, pulled the bezel off and disconnected the screen, then removed the protective film around the lcd board. During board inspection there was a resistor that was barely attached to only one pad, a tiny amount of force with tweezers got this to move completely off, and unfortunately too far away as it is now lost.. I don't know if this is the...
    11-02-2024, 04:44 PM
  • eccerr0r
    lowest current galvanometer/analog meter (passively powered!)
    by eccerr0r
    Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
    On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
    04-16-2025, 12:41 AM
