Trouble understanding VREF for VTT generation.
  • thanibee
    • Nov 2016
    • 22
    • India
    I am having a MSI g41 motherboard. The VTT voltage for north bridge should be around 1.2V. But it is generating only 0.9V. The 1.2V VRef is coming from SIO chip. See the attachments for reference. Any help appreciated. Thanks
  • mon2
    • Dec 2019
    • 14021
    Re: Trouble understanding VREF for VTT generation.
    No. The pins you are showing are also connected to the same ref 1v2 voltage rail. The source of this power rail is somewhere else in the schematic. Check your power supply area or search the exact text to locate the true voltage source.
    • thanibee
      • Nov 2016
      • 22
      • India
      I am having trouble finding the source of this VREF.
      I have attached the pdf (password is 254422)of the schematic here. Please help finding it.
      • mon2
        • Dec 2019
        • 14021
        Check U6 on top-right of sheet 30. What is the voltage on Vout?
        Voltage on pin 5,6,7,8 of U6?
        • piernov
          • Jan 2016
          • 4435
          • France
          The voltage references come from the SIO. According to its datasheet, they are 0.9V by default.
          So 1_2VREF = 0.9V (feeding U14A non-inverting input), and V_FSB_VTT = 1.2V (since U14A inverting input stabilizes at 0.9V thanks to the voltage divider R296/R297).
          • thanibee
            • Nov 2016
            • 22
            • India
            Makes sense. Thank you.
            • maneatingmonkey
              Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
              by maneatingmonkey
              I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
              There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
              03-27-2024, 07:17 AM
            • Stefo
              Help Understanding Darlington IC
              by Stefo
              Have a question above my understanding. (see attached pic and datasheet). Attempting to repair a pcb with a burnt out Darlington Transistor IC. I have identified all pins except for nos. 11 & 12 (Output 7 &8). I removed what is left of the IC, but could not find any traces as to where these pins might have been connected. Bad choice of words, there is no trace of any circuit trace for either pin. In the surrounding circuits i cannot find any without a verified connection to other components. My question is it possible these two pins are just hanging out there with no connection, nothing...
              01-11-2024, 09:14 PM
            • w1nk0
              Thinkpad X1 Carbon 5th Generation DX120 NM-B141
              by w1nk0
              Hello!
              I'm looking for help with Thinkpad X1 Carbon 5th Generation DX120 NM-B141:
              - no image
              - fans spins for second or two (not sure why once it is second and once its two or smth)
              - keyboard and power button lights for split second
              Not sure about SN because sticker got worn after time.
              Any help would be appreciated!...
              07-07-2025, 05:27 PM
            • Matthew Morrone
              Lenovo Thinkpad Yoga x1 3rd Generation
              by Matthew Morrone
              machine type model: 20LD0038AU
              system unit serial no: R90RKCWP
              system board serial no: W1KS88K10YS
              Current Bios Version: N25ET68w (1.54) Date: 22/8/24
              i currently have access to the os i can log in and everything but cannot change the bios settings due to supervisor bios password lock. any help with this would be amazing as i have run out of things to try and dont have a reader to create the dump file.
              my apologies if i have missed something... im a new member...
              01-05-2025, 09:12 AM
              Apple iPad 4th Generation 820-3249 Boardview and Schematic
              Apple iPad 4th Generation 820-3249 Boardview and Schematic...
              11-01-2024, 02:45 PM
