ASUS X556UJ_MB rev 2.0 boardview
  • aanev
    • Feb 2013
    • 20
    • macedonia
    Can someone send me boardview for ASUS X556UJ_MB rev 2.0 or similiar?
  • peste
    • Dec 2016
    • 13600
    • ROMANIA
    Re: ASUS X556UJ_MB rev 2.0 boardview
    try..
    • Rahit
      • Mar 2021
      • 1
      • bangladesh
      tnx bro
      • alexm22
        • Sep 2019
        • 37
        • argentina
        thank you
        • gtferrari
          • Aug 2017
          • 10
          • Greece
          Hi. Do you have the schematic for this board?
          • gtferrari
            • Aug 2017
            • 10
            • Greece
            Originally posted by peste
            try..
            Do you have the schematics for this board? I have searched everywhere with no luck. I can't even find it in payed sites. I have a short circuit and I need it to fix my board.
            • mon2
              • Dec 2019
              • 14667
              @gtferrari - found a repair guide but is locked. Will PM you.
              What is the issue with your board ? Often it is possible to service without schematics.
              Post the details in the laptop side of the forum.
                • 21907
                The repair guide is widely available if you google it,its on a some free schematic/bios sites
                • gtferrari
                  • Aug 2017
                  • 10
                  • Greece
                  Thanks for the reply. I have found this repair guide but I wanted the schematics. Even without the repair guide and using only the boardview I had found that I have a short circuit on the +1.0 VSUS to the ground and +1.8 VSUS to the ground. That's why I wanted the schematics to find out what is this voltage feeding to isolate this power and finally find the defected part. If I don't find it my only hope is the boardview and removing the parts that this voltage connects to. Both voltages goes to the CPU and I want to be sure that the CPU is the problem before throwing the board.
                  • mon2
                    • Dec 2019
                    • 14667
                    What is the resistance to ground that you are measuring on these rails ?
                    • gtferrari
                      • Aug 2017
                      • 10
                      • Greece
                      Thanks for the reply and sorry for the late response.
                      Both are below 1ohm. It is a short circuit for sure but without the schematic it won't be an easy fix. I need to find the trail and see what components take part to this voltages and try to isolate the problem.
                      • mon2
                        • Dec 2019
                        • 14667
                        Using a power supply, set for 1v0 (not higher) and 2A scale or whatever your power supply can support.
                        Do not apply power to the logic board / no battery.
                        Use the above external power supply @ 1v0 setting to inject this voltage onto the 1v8 rail and check for which part is heating up.
                        You can use IPA (alcohol) poured over the parts and check for where the alcohol evaporates the fastest. Test it a few times but often, we found, a bad shorted tantalum cap will start to smoke / mist the alcohol. Remove that part and test the resistance to ground again.
                        Post your updates but this is the general procedure for your case. There are some excellent videos on youtube about this process. Check ADAMIT (I believe is the poster - the dude with the goatee).
