Reattaching a small cap on a Voodoo5 5500 AGP
  • w.gruffydd
    • Jul 2020
    • 3
    Greetings,
    How hard would it be for a complete soldering novice to reattach this small capacitor (circled in red) on a Voodoo5 5500 AGP?
    It's currently detached on one side:
    Alternatively, is there a place where people are referred for graphics card cap repairs? From what I can see, badcaps only does motherboards. Given the prices of Voodoo5s these days, I cannot afford to screw this up.
    Thank you advance!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Reattaching a small cap on a Voodoo5 5500 AGP
    I'm sure Topcat would do the board if you want it.
    This is not something I would recommend a novice try as his first thing.
    Boards like these require allot of heat due to large ground planes.
    If you want to do it yourself you need to practice on something else first.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      I could fix that.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • w.gruffydd
        • Jul 2020
        • 3
        Very cool. Would you like me to fill out this form?
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Yea, that's fine.
          Team : 49813
          Join in!!
          Team Stats
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Also worth keeping in mind that although unusual sometimes these caps do go bad.
            Case in point (there is even a Mouser shopping cart on page 2...)
            https://www.vogons.org/viewtopic.php?p=668010#p668010
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              If you don't have any prior experience soldering, SMD/SMT can be a bit tricky.
              I learned to solder SMD by myself, but it took many years of practice and experimental repairs on broken boards no one cared about before I learned to do it right. You don't actually need any specialized tools for most small SMD components (I still use a cheapo 35-Watt Radio Shack soldering for most of my SMD work), but you do need an iron with the right tip and also good paste flux. And a steady hand.
              That said, I still despise removing electrolytic SMD caps. Soldering them back on, not so much of an issue, though.
              This being a rare VooDoo card, of course... probably better that you decided TC to do it.
              • diif
                • Feb 2014
                • 6978
                • England
                Grab the top with pliers and give it a gentle twist clockwise and anti clockwise.
                This snaps the legs which can then be desoldered easily.
                (As recommended by Mr Carlson of Mr Carlson's Lab).
                  • Jul 2011
                  • 6065
                  Originally posted by diif
                  (Mr Carlson's Lab).
                  This is a very good resource of information I am a regular reader of his material
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Thanks for the recommendation, diif.
                    That actually sounds somewhat similar to how I've been doing them: typically, freeze the board and then just exert sideways force on the cap. If the board uses very stiff lead-free solder, freezing it actually makes the solder very brittle so the leads become easy to snap off from the board without getting damaged at all - sometimes looking as if the cap is perfectly desoldered. But YMMV with different boards, as did mine. On some, the cap leads broke close to the cap base and with those I either had to discard them or solder on new leads (most often the case, as I don't like to waste good caps. )
                    I'll check Mr Carlson's Lab and see what he does. Been a while since I checked that. Never know, might (probably will) learn something new.
                      HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                      This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 03:44 PM
                      HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                      This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-12-2024, 03:36 PM
                      HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i3-4130 Specification for Upgrade or Repair
                      This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                      09-12-2024, 03:28 PM
                      HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-4570 Specification for Upgrade or Repair
