Not Laptop - Asrock Z87 Extreme 4 BIOS required
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I tagged this on to an old repair thread a few days ago but maybe it was missed there
    I'm looking for BIOS for Asrock Z87 Extreme4.
    I need a BIN or ROM file as the motherboard will not POST
    The files on Asrock website are for DOS or Windows or the BIOS update util.
    None of them contained a BIN file. I thought the Windows version may allow me to write a BIN file to disk, but when I run it on another PC it just opens blank DOS window for a second and that's it.
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    • 21948
    Re: Not Laptop - Asrock Z87 Extreme 4 BIOS required
    The instant flash versions are the easiest to work with, it is a BIN with different filename extension and a 4KB header .Delete the header with a hex editor to get the full bin, then rename it to bin or rom .
    The attatched bios is the 3.50 beta version.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Thank you
      • Aliencomputres
        • Aug 2019
        • 218
        • România
        The instant flash versions are the easiest to work with, it is a BIN with different filename extension and a 4KB header .Delete the header with a hex editor to get the full bin,then rename it to bin or rom .
        The attatched bios is the 3.50 beta version .
        Thank you!
        • to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
          by to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
          I have opened the laptop and identified the main BIOS chip...
          10-24-2025, 01:35 AM
        • nolaryie
          BIOS .bin file for ASRock B450M Steel Legend
          by nolaryie
          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
          Thank you!
          08-06-2025, 12:01 PM
        • Citymin
          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
          by Citymin
          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
          The charging red LED lights up, but the charging screen doesn't show any indication.
          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
          (I've tried removing the battery and resetting the device, but the issue persists.)
          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • iZakre
          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
          by iZakre
          Hello everybody!
          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
          The thing is that I had installed TeamViewer and could log into the computer...
          02-19-2023, 02:27 PM
        • m1ch43lzm
          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
          by m1ch43lzm
          Hi everyone
          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
          There's also an extra OTP Secu.R...
          09-06-2025, 05:47 PM
