Does anybody know can I use CH341A programmer for flash XMC qh128ahig chip and if not which model of programmer I need to have? (I was read something about this chip is not so common and found info. that many SPI-programmers are not compatible and cant write just read from this chip).
XMC qh128ahig chip
Re: XMC qh128ahig chip
Originally posted by voodoop View PostI have the same chip and I can't read it with RT809F .
It is not listed either .
https://www.hklrf.com/24download/img/RT809F-List2.txt
https://www.hklrf.com/RT809F-Programmer_3546.html
Code:001: ÐòÁкţº20180308212215-006326£¬±à³ÌÆ÷¹Ì¼þ°æ±¾£ºV3.0 ¡£ 002: Auto identified 9 ID is match with the partnumber. 003: http://www.ifix.net.cn/thread-2550-1-1.html 004: The currently selected:XM25QH128A@SOIC8-200, capacity: 128Mbits, 16Mbytes. 005: >------------------------------------OK---------------------------------------< 006: Chip pins contact is detected OK. 007: Chip ID verification OK. 008: Start reading chip...... 009: Status register1 values: 0x0 ¡£ 010: Read successful£¬Elapsed time£º26.34 seconds¡£ 011: Auto verifying... 012: Chip verification error, start position: 0x600000. 013: Verification failure£¬Elapsed time£º4.015 seconds¡£ 014: Read error, operation aborted.
I tried with all identified chips .Last edited by voodoop; 10-16-2020, 01:36 AM.
Originally posted by luiscwb View PostRT809F list but does not read or write, there is an error. Which programmer supports this eprom?
For TL866CS
NOTE: The Check ID option must be unchecked
XMC QH64AHIG (XM25QH64AHIG): Compatible with
W25Q64FVSIG GD25Q64CSIG MX25L6406E EN25QH64A W25Q64JVSSIQ
XMC QH128AHIG (XM25QH128AHIG): Compatible with
W25Q128FVSIG GD25Q128CSIG MX25L12845E EN25QH128A W25Q128JVSQ
These work at 3.3v so no adapter will be necessary
I hope it serves you
Greetings to all
Greetings to all
Greetings to all
Hi. I have XMC QH128AHIG and TL866CS programmer. I tried to read the data but no result. I set the programmer to the W25Q128FV model and for two minutes it displays the message: Reading Code memory. Result, all addresses have the content 00. Check ID turned off. What else can I do?
Originally posted by Synne View PostDoes anybody know can I use CH341A programmer for flash XMC qh128ahig chip and if not which model of programmer I need to have? (I was read something about this chip is not so common and found info. that many SPI-programmers are not compatible and cant write just read from this chip).
