XMC qh128ahig chip
    XMC qh128ahig chip
    Does anybody know can I use CH341A programmer for flash XMC qh128ahig chip and if not which model of programmer I need to have? (I was read something about this chip is not so common and found info. that many SPI-programmers are not compatible and cant write just read from this chip).
    Re: XMC qh128ahig chip
    RT809 series programmer works with XMC chips and it is listed there. Dont know about CH34A
      thank you very much on useful info
        I have the same chip and I can't read it with RT809F .
        It is not listed either .
          It is listed.Update your software version .
          https://www.hklrf.com/24download/img/RT809F-List2.txt
          https://www.hklrf.com/RT809F-Programmer_3546.html
            Code:
            001: ÐòÁкţº20180308212215-006326£¬±à³ÌÆ÷¹Ì¼þ°æ±¾£ºV3.0 ¡£
            002: Auto identified 9 ID is match with the partnumber.
            003: http://www.ifix.net.cn/thread-2550-1-1.html
            004: The currently selected:XM25QH128A@SOIC8-200, capacity: 128Mbits, 16Mbytes.
            005: >------------------------------------OK---------------------------------------<
            006: Chip pins contact is detected OK.
            007: Chip ID verification OK.
            008: Start reading chip......
            009: Status register1 values: 0x0 ¡£
            010: Read successful£¬Elapsed time£º26.34 seconds¡£
            011: Auto verifying...
            012: Chip verification error, start position: 0x600000.
            013: Verification failure£¬Elapsed time£º4.015 seconds¡£
            014: Read error, operation aborted.
            I get this error with the latest version .
            I tried with all identified chips .
              for me also same error any solution guys
                If it reads successfully but gives verification error-then the chip itself is bad. You need to replace it.
                  its 10th gen laptop and that bios is working fine i wanna read and copy for othe laptop but i cant read from this chip. i have tried from ch341 and rt809f
                  and i'm using the latest updated versions
                    good night like i also have ch341 and it does not detect it
                      RT809F list but does not read or write, there is an error. Which programmer supports this eprom?
                        https://www.youtube.com/watch?v=nA--ggJUaj0
                          For TL866CS
                          NOTE: The Check ID option must be unchecked
                          XMC QH64AHIG (XM25QH64AHIG): Compatible with
                          W25Q64FVSIG GD25Q64CSIG MX25L6406E EN25QH64A W25Q64JVSSIQ
                          XMC QH128AHIG (XM25QH128AHIG): Compatible with
                          W25Q128FVSIG GD25Q128CSIG MX25L12845E EN25QH128A W25Q128JVSQ
                          These work at 3.3v so no adapter will be necessary
                          I hope it serves you
                          Greetings to all
                            Vicarinat i have minipro tl866a does it work on that minipro by uncheck id...
                              vicarinat great tips is working fine
                                Originally posted by Vicarinat View Post
                                For TL866CS
                                Greetings to all
                                  For TL866CS
                                  Greetings to all
                                    Good day, I just checked NEO Programmer and the MXqh128a is on there, will try it out today if you need feedback.
                                      Hi. I have XMC QH128AHIG and TL866CS programmer. I tried to read the data but no result. I set the programmer to the W25Q128FV model and for two minutes it displays the message: Reading Code memory. Result, all addresses have the content 00. Check ID turned off. What else can I do?
                                        Did you find any solution to your problem? I have the same chip and I need to read write to it.. Hope you have the solution by now...
