asus x540ubr schematics or board viewer please
  • pcnetch
    • Aug 2013
    • 125
    • Sri Lanka
  • prageeth badcaps
    • Jun 2014
    • 13
    • Sri Lanka
    Re: asus x540ubr schematics or board viewer please
    please I also need...thank you...
    • ex-byte
      • Mar 2022
      • 18
      • iran
      Hello friends, I need help. I need a schematic or board view of the Asus X540 UBR ver2.0 motherboard. Thank you
      • mon2
        • Dec 2019
        • 14672
        See attached. Sharing all the Asus X540 boardview files from my database - perhaps one is close to yours.
        • ex-byte
          • Mar 2022
          • 18
          • iran
          thank you for answer
          • ex-byte
            • Mar 2022
            • 18
            • iran
            Board view was suitable for my work. Do you also have X540UBR ver2.0 a manual board repair service or block diagram?
            • mon2
              • Dec 2019
              • 14672
              Will check after some more beauty rest.
              Which boardview file matched your logic board?
              • ex-byte
                • Mar 2022
                • 18
                • iran
                O yeah
                X540UV 2.0
                • mon2
                  • Dec 2019
                  • 14672
                  Sorry - have only the attached. Let me PM you.
                  • ex-byte
                    • Mar 2022
                    • 18
                    • iran
                    Oh no
                    thank you anyway
                    • mon2
                      • Dec 2019
                      • 14672
                      What is the fault of your unit ? Maybe we can fix it without the schematic.
                      https://www.youtube.com/watch?v=cS9yh66U9Fg
                      • ex-byte
                        • Mar 2022
                        • 18
                        • iran
                        I removed all the additional equipment, including the hard disk, DVD burner, LCD monitor, etc., but this IC heats up according to the figure and draws a current of about 0.16.
                          • 21922
                          The picture is too small to see the marking code on the chip..
                          • ex-byte
                            • Mar 2022
                            • 18
                            • iran
                            2n6bc05
                            • mon2
                              • Dec 2019
                              • 14672
                              It will be Richtek part with '2N=' markings.
                              RT8249CGQW
                              https://a.aliexpress.com/_m0zucQc
                              • ex-byte
                                • Mar 2022
                                • 18
                                • iran
                                Do you think this IC is burned out? Because I do not have the repair manual for this motherboard
                                • mon2
                                  • Dec 2019
                                  • 14672
                                  How hot does this chip get?
                                  The above datasheet has the pinout. With care, check the voltage of PGOOD pin and post the measurement here.
                                  Also check voltage of LDO3 and LDO5.
                                  Post the voltage of each.
                                  Do not short the pins of this IC.
                                    • 21922
                                    It would be better to start a new thread in the main forum.
                                    • ex-byte
                                      • Mar 2022
                                      • 18
                                      • iran
                                      ok.sure
                                      • flayer23
                                        • Apr 2012
                                        • 13
                                        • france
                                        thank you -mon2- it's helpfull
