Lenovo b5400
  • basemyounes
    • Sep 2017
    • 79
    • gaza
    Lenovo b5400
    Please i need kbc file for program io on motherboard da0bm5mb8d0 rev lenovo b5400
    • 22279
    Re: Lenovo b5400
    What is the serial number, or model type .
    • laptopcenter
      • Mar 2019
      • 90
      • haifa
      Re: Lenovo b5400
      Thank you for answer
      Lenovo B5400_Quanta BM5_U45
      MB number : DA0BM5MB8D0
        • 22279
        Re: Lenovo b5400
        What is the machine type,or serial number (Type: 20278 ???)
        Post your bios backup .
          • 22279
          Re: Lenovo b5400
          Bios + EC .
          DMI
          W 6AFF5E
          M 40122F
          M 401013
          SN 40101A
          • laptopcenter
            • Mar 2019
            • 90
            • haifa
            Re: Lenovo b5400
            Bios + EC .
            DMI
            W 6AFF5E
            M 40122F
            M 401013
            SN 40101A
            thanks i will try test it and tell you ..
            • fefo1993
              • Nov 2023
              • 8
              • Italy
              Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
              Hi, i have a Lenovo B5400 with locked bios (supervisor password) and seems that Auto-Patcher doesn't work with it.
              I tried to flash patched bios, and it boots up because i receive the screen "press any key, press two times space bar, etc.. and the final screen "turn off machine", but when i reflash stock dumped bios, the lock is always here.
              Any ideas??
              Here my Serial Number: QB08704354
              In attachment dumped and patched bios files.
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1372
                • France
                Any ideas??
                try clean this
                • fefo1993
                  • Nov 2023
                  • 8
                  • Italy
                  Originally posted by Maxpower3
                  try clean this
                  i see inside dumped and patched bios, but i don't have this value like your screen, i have "empty" values (all "FF")
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1372
                    • France
                    yet I find good in both dumps
                    try test unlock
                    EDIT : I forgot 2 values, I modified , test both unlock
                    B8 B8
                    • fefo1993
                      • Nov 2023
                      • 8
                      • Italy
                      try test unlock
                      ah ok, now i find it also in my files! so now i clear this 4 lines and will try to dump and check if it works.
                      can you give me the name of the tool that i can see on the left side of your first screenshot? thanks
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1372
                        • France
                        can you give me the name of the tool? thanks
                        UEFITools
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1372
                          • France
                          try test unlock
                          B8 B8
                          if you have error bad SVP data, change the end put back the 8B C5 04 41, remove only the 3 lines from the beginning
                          look pics for compare with clean by setup
                          • fefo1993
                            • Nov 2023
                            • 8
                            • Italy
                            i have exactly "SVP" error...but deleting the first three lines, now i have black screen and no boot or sound.
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1372
                              • France
                              do you have access when SVP error or power off direct?
                              try another maybe
                              edit:
                              otherwise we can try a jump here, if no one has any other solution.
                              After bypass you will have to enter a new password or otherwise blank with entry.
                              the checksum will thus be corrected, you can leave bypass or remove with a new read and restore the modification
                              00 isn't FF
                              Multi edit We should continue here, https://www.badcaps.net/forum/showth...t=Lenovo+B5400
                              I hadn't seen that they talked about EC for this model. We are in the right place given the SVP error, must have a mirror map in the KBC maybe.
                              a moderator can move the thread perhaps ??
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1372
                                • France
                                in the SMDFlea files it's like this
                                https://www.badcaps.net/forum/showpo...32&postcount=5
                                • fefo1993
                                  • Nov 2023
                                  • 8
                                  • Italy
                                  try another maybe
                                  edit:
                                  00 isn't FF
                                  "test3" file in the rar WORKS! so now i have no password and unlocked bios! thanks!!
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1372
                                    • France
                                    no point doing the KBC then
                                    • bel77
                                      • May 2013
                                      • 34
                                      • jordan
                                      need bios file
                                      model : 20278
                                      sn qb07812057
                                      • peste
                                        • Dec 2016
                                        • 13924
                                        • ROMANIA
                                        post full name and model, motherboard model,etc.
                                        post the contents of the bios chip even if it is corrupted..​
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
                                        • derradji89
                                          Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                          by derradji89
                                          Hi everyone 🤗
                                          I have a Lenovo MIX 320-10lCR computer.**
                                          1. **Operating System**: Windows 10 ** Education** 64-bit.
                                          2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                          3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                          4. **BIOS Chip Reflashing**: Currently,...
                                          04-19-2025, 03:04 PM
