I have this one from E-recycle sitting around for about month so I decide to take a look at it today.
It has 5-blink code for T-CON error, so first thing I check is the 2A fuse on the integrated T-CON board, sure enough the fuse is blown.
I check the resistance on the output side of the fuse, it shows <1 Ohm so I start checking the cap and the protection diode right next to the fuse. I remove the diode but the shorts is still there, so I remove the cap right next to the Diode then the shorts went away, the resistance against GND is now showing around 10K Ohms. I am very lucky that the first cap I removed is the bad one otherwise there will a lot of probing and may involve using power supply or using super low Ohm meter for tracing for the shorted parts.
I also check the backights setting, it looks like the old owner already had it set to 6 for all inputs.
