Dell E7450 ZBU11 LA-A963P BIOS DUMP NEEDED
  • andrew25
    • Feb 2016
    • 222
    • Malawi
    If anyone has please share the dump
    Dell E7450
    ZBU11 LA-A963P
    2014-10-09
    rev: 1.0(00)
  • nacer
    • Feb 2016
    • 130
    • alger
    Re: Dell E7450 ZBU11 LA-A963P BIOS DUMP NEEDED
    you got it
    • andrew25
      • Feb 2016
      • 222
      • Malawi
      this one not working, LA-A961P does not have GPU while my LA-A963P has dedicated GPU
      • reverendalc
        • Jul 2016
        • 81
        I also need this! Did you find it?
        This isn't Monaco... This is Baghdad
        • reverendalc
          • Jul 2016
          • 81
          i found this but no satisfaction
          • reverendalc
            • Jul 2016
            • 81
            i have tried a million (maybe actually 5) different internet dumps, including several purchased from biosfix.
            the power button illuminates, the fans spin for a few sec, then they HDD light flashes for a split second as everything stops. repeat. on the third try (in a row) i'll get a good fast spin from the fan for a few seconds, then it's back to the normal routine.
            this laptop booted fine from the original bios (with unknown SVP), but i forgot to make a backup of the 4mb chip, so now i can't restore it to any bootable state, but i know for a fact it works fine.
            help?
              • 21002
              help?
              The password is stored in the MEC5085 . You can find out which dell models have the password stored in the MEC by searching for the Statement of Volatility document per model .
              Flash the MEC if you have a kbc programmer, and the bios .
              • reverendalc
                • Jul 2016
                • 81
                hello again SMDFlea. i hope that once again you might save me!
                i cannot restore this laptop to bootable state. i made backup of UC2, but neglected to backup UC3 or UV9 before trying various internet dumps. most BIOS downloads include only UC2 and UC3, which suggest those alone are good enough to restore corrupted BIOS, but I have tried at least seven different packages now with no success.
                • imranromi
                  • Jan 2015
                  • 1288
                  • Pakistan
                  Plz post 1 pics bios password..
                  • reverendalc
                    • Jul 2016
                    • 81
                    does anybody know what the UV9 chip does? most of the bios i download has only UC2/UC3, but some have UV9 also. i have tried flashing all three from two different matching sets with no luck, only quick fan spin and flash of LED lights.
                    i have taken internet dump and merged files, clean ME, and rebuild but no success. i did this with only UC2/UC3, no idea what UV9 is for.
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      do you still have original backup your UC2?
                      post here i'll try to help to rebuild new one for you...
                      • reverendalc
                        • Jul 2016
                        • 81
                        Here is the original, unmodified UC2 dump.
                          • 21002
                          Here`s UC2 and UC3 with clean ME, also UV9
                          • reverendalc
                            • Jul 2016
                            • 81
                            Oh snap. I’ll buy you a beer if this works, I’ve spent probably $20 on internet dumps, hours translating Russian and Portuguese forums and registering to download dumps, etc. with no satisfaction.
                            I have to FULLY disassemble this unit to flash UV9, and then fully reassemble to test. I’m so sick of it!
                              • 21002
                              You`ll still have the bios password after flashing. At post #9 imranromi said "Plz post 1 pics bios password.." . He may be able to give you a code to enter to remove the password.If the password can`t be removed that way, you`ll have to flash/edit the MEC .
                              • reverendalc
                                • Jul 2016
                                • 81
                                yes yes, SVP is not mission critical, there are no lockdowns in place, it was simply an annoyance. if I can restore operation to this machine, i will pursue that as well... i don't believe this laptop is old enough to unlock with the hash, but certainly worth a shot.
                                • rioreno
                                  • Feb 2009
                                  • 540
                                  • Indonesia
                                  here you can try IF smdflea files doesnt work...
                                  Your orginal bios are ver. A019
                                  so base on your original file ... i try to rebuild UC3 from extracted e7450a019.exe and UC2 withclear NVRAM...
                                  UV9 use from smdflea...
                                  goodluck
                                  • reverendalc
                                    • Jul 2016
                                    • 81
                                    @SMDFlea, once again, you are my hero. haven't seen that laptop POST in almost a week.
                                    i decided to take apart the laptop, and use a dremel to expose the BIOS chips so i could do this without taking everything apart and putting it back together.
                                    after all that work, i flashed SMDFlea's BIOS, and it booted right up. oh well.
                                    I COULD KISS YOU ON THE MOUTH. but i won't.
                                    there's no sound tho, so it appears i'll have to tear it back down and figure out what gives. i am so over this laptop.
                                    i can't thank you all enough, and wish i had the skills to sort these UEFI bios out myself.
                                      • 21002
                                      Glad its working,i`ll settle for a beer thanks .
                                      • isc
                                        • Jun 2016
                                        • 11
                                        • istanbul
                                        thanks so much
                                        working fine
                                          DELL Latitude E7450 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude E7450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7450 boardview and E7450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-06-2024, 04:40 PM
                                          09-06-2024, 04:10 PM
