Vizio E500I-B1 : Power Supply Board Repair - 715g6100-p04-003-002h
    I am troubleshooting why my TV will not turn on. It has been turning off randomly and now it will not power on. I believe I have traced the problem to be a bad Integrated Circuit on the power supply as well as a couple resistors connected to the IC. In my research i found that the IC9301 is what is responsible for the 5vdc standby power. I do not have 5vdc on the standby power terminals. So I am receiving a new IC from digikey today that I am going to install. However on the back of the board there are the two resistors that are connected to pin 1 of IC9301. Unfortunately I haven't been able to find a schematic or even a picture of the back of the board that would show me what value of resistor i need to get to repair it. Does Someone have this info? I have looked through the thread that has links for service manuals and not one of these sites has my TV model or a similar model that might use the same or similar power supplies.
    I have attached two pictures. one of the bad IC9301 removed from the circuit board. the other of the back of the board where i need to replace the resistors.
    Re: Vizio E500I-B1 : Power Supply Board Repair - 715g6100-p04-003-002h
    Looks like they are both 1R2
      Thanks so much!! I couldn't find a clear enough picture of the back to see the writing.
        https://www.badcaps.net/forum/attach...6&d=1502902467
        You should also verify that fusible resistor R9301 is not blown open circuit when that SMPS IC blew up.
          Hello my name is Alan and I live in Northern Virginia, I am a serial entrepreneur by day and and electronic repair newbie in my spare time. I just found this site this evening while looking for a schematic for my Visio flat screen TV. Hope everyone is having a great evening and take care.
