LG 60PV450 - Image Retention, Turns Off
  • tabascojoe
    • Feb 2017
    • 7
    Our LG 60PV450 is acting strange and I believe its a bad board. Looking for advice on what board it could be.
    A few months ago we noticed an electronic burning smell coming from the set. Unplugged it, waited a day and plugged it back in. The smell was gone but the image was not right. On the top and bottom 3rd of the screen the image had color bleeding (noticeable with white images the most) and would retain images. It was something that didnt bother us so we dealt with the issues. (image attached of the color issue)
    Last week the set started to turn off after about 15 minutes of viewing. The frequency of the set turning off increased and now it turns off after 20 seconds. This is where I decided to open it up and check the boards for noticeable issues. From my untrained eye I did not see any obvious signs of damage but took pictures of everything.
    Given the symptoms could it the zsus or ysus, or something else?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: LG 60PV450 - Image Retention, Turns Off
    Take a look under the y & z boards for bad or cracked solder joints on the inductor coils. Very common on this model.
    • tabascojoe
      • Feb 2017
      • 7
      Attached are pics of the bottoms, I did not see bad solder joints, but maybe the pics tell a different story.
      • sordids999
        • May 2013
        • 2152
        • uk
        try resoldering the connections i have highlighted with red circles
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          + 1
          • tabascojoe
            • Feb 2017
            • 7
            I was just about to reply on how blind I was to miss that...
            Is the carbon looking deposit around the joints pause for concern? Could that indicate bigger issues?
            • dskall
              • Oct 2016
              • 2905
              • usa
              Carbon is from arcing. It's possible you might have to remove coils and clean terminals with sandpaper to get a good solder joint.
              • tabascojoe
                • Feb 2017
                • 7
                My soldering skills are awful. I never learned the proper technique.
                I solder the best I could and it fixed the issue. I just don't know how long my joints will hold. If it does break again I'm going to put out an ad to hire someone with soldering skills.
                Thanks to BadCaps and the members for helping me out.
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Good fix! I had the same problem on 3 of this model.
                  • andrhouseolly
                    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                    by andrhouseolly
                    Hi.
                    I kindly ask you to help me solve the problem.
                    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                    The board turns on, there is no image.
                    Read more. When the power supply is connected, the front panel indicators light up briefly.
                    When you press the power button, the button indicator lights up. The board works
                    there is no image, there is no matrix initialization, there is no image on HDMI.
                    When turned on, the fans do not spin, but when they warm up they start spinning.
                    When you turn off the button, the fans spin up to full speed for a short...
                    05-11-2024, 03:14 PM
                  • waakye
                    ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
                    by waakye
                    Hi everyone,
                    I was giving this ASUS ROG G750JM that exhibit the following behavior:
                    When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
                    My issue is the laptop doesn't stay on for a long time and turn itself off.
                    Any lead on how to resolve this will be appreciated.
                    I cannot boot in windows and no liquid damage.
                    Thanks in advance.
                    09-13-2024, 08:10 PM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
                    HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                    09-06-2024, 10:56 AM
                    HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
