polymer caps
  • halaster79
    • Jul 2016
    • 39
    • usa
    polymer caps
    is it safe to use aluminum polymer caps to replace the aluminum caps, as long as the uf and v are the same, they have the right diameter and wire space, and are of equal or lesser ESR, on a motherboard? in the datasheet when it says polymer cap ESR is 9, does that mean the same thing as .009 on an aluminum cap?
  • mariushm
    • May 2011
    • 3799
    Re: polymer caps
    Polymer capacitors usually have lower esr compared to their electrolytic counterparts. ex a 1500uF 6.3v electrolytic may have 10 mOhm esr, while a polymer would be smaller in height and slightly lower esr.
    On motherboards, yes, in most locations it should be safe to replace electrolytic capacitors with polymer capacitors. Try to keep the esr relatively the same though, or a bit lower.
    In the VRM circuit (those capacitors very close to the cpu socket) it should be safe to use polymer capacitors of slightly lower capacitance and voltage.
    For example they may use 4-8 x 1'000-1'500uF 6.3v capacitors in parallel to obtain lower esr. They don't need 6'000-10'000uF and they don't need a 6.3v rating when the top voltage on the cpu would be less than 1.5v, but they simply used 6.3v and 1000-1500uF per capacitor to get the lowest esr possible in the height available there by the cpu (any higher would have blocked cpu coolers). If replacing those with polymer capacitors, you could replace the electrolytics with 4v rated (or even 2.5v rated) polymers and only 680-820uF in capacitance, as they'll have the same esr and the total capacitance would still be more than enough.
    • 2andrewd
      • Mar 2012
      • 41
      • us
      Re: polymer caps
      why would you want to use polymer over E.L. Mehhhh
      • halaster79
        • Jul 2016
        • 39
        • usa
        Re: polymer caps
        bored and looking at the Nichicon PLG series on digi-key. they seem to have really ultra low ESR if 9 means the same as .009 ESR on regular aluminum caps. some regular aluminum ultra low ESR caps are getting kinda hard to find, or are starting to get old, like the 1200uf 6.3v Rubicon MCZ, and some of the Nichicon HN and HZ series, or could be fakes.
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          Re: polymer caps
          Because polymer caps have solid electrolyte, so they have better reliability at high temperature. This is especially important for Intel socket 775 and newer motherboards, where the caps can be placed under the heat sink.
          Polymer caps are also smaller. With everything being shrunk-down these days, polymers are almost a necessity for new motherboards.
          Yes.
          Many polymers state their ESR in mOhms (milliOhms), which is 1/1000 of an Ohm, whereas old electrolytics typically specify ESR in Ohms.
          So 9 mOhms = 9/1000 Ohms = 0.009 Ohms
          • halaster79
            • Jul 2016
            • 39
            • usa
            Re: polymer caps
            Is ripple current higher 6000 or equal safe when replacing a lower ripple current aluminum 1200 cap, for example?
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              Re: polymer caps
              Yes.
              The Ripple Current (RC) rating of a cap simply specifies how much AC current the cap can take before it starts to overheat internally. Thus, if the old caps are only rated for 1200 mA of RC and they worked for many years, then the new caps will work for even longer, as the ripple current in the circuit won't get anywhere near their maximum RC rating.
              • 13mh13
                Aluminum SMD caps vs thru hole caps (reliability)
                by 13mh13
                The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
                https://i.postimg.cc/kGrR6BpZ/image.jpg
                I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
                I have not tested/replaced those alum. SMD electro PCB caps.
                Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
                All the thru hole electros I removed / replaced on this CDP (and most...
                04-05-2024, 07:41 PM
                by momaka
                03-15-2023, 10:17 PM
              • eryjus
                Heathkit IO-4205 Power Supply Caps
                by eryjus
                First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                05-10-2023, 11:21 AM
              • dragon3x
                After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                by dragon3x
                Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                power on.
                Here are some examples :
                (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                switching supply area).
                (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                than 6.3 V.)
                1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                I replaced capacitors with aluminum-polymer.
                3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                03-21-2025, 02:46 PM
              • Paxman_Swede
                Identifying caps on an old Zoom 9000
                by Paxman_Swede
                Hello!
                I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                I have studied the board and...
                01-14-2025, 09:51 AM
