Soltek motherboards, bad caps and no POST
  • Agent24
    I see dead caps
    • Oct 2007
    • 4960
    • New Zealand
    Recently got a box of old cheap motherboards, and now got a few questions as well:
    Pulled out the best board in the box in the hopes of using it but the big 1500uf caps are bulging and some are leaking slightly - and I can't get it to POST.
    The board is a Soltek SL-65ME, there was also a Soltek SL-65KV2-T in there as well, which has almost identical cap failure and doesn't POST either.
    Now I'm thinking that the caps are causing the problem, but I didn't think they'd cause problems this bad, or if they did, it would be rare..
    Now can anyone tell me if this is likely caused by the caps (common in these boards to cause POST failure?) or if the boards are more likely totally stuffed?
    There appears no damages or other faults apart from the bad caps, nothing burnt etc...
    You can see them in detail here, they aren't horrifically bad, which is why I thought they may be still good enough to work: http://flickr.com/photos/agent_24/2327954411/
    I was also thinking, if there was any sense in trying a recap, should I just do the 1500's or the 1000's next to them as well? (the 1000's aren't visually faulty), but are they likely to be bad?
    -David VanHorn
  • kikkoman
    • Jul 2007
    • 691
    Re: Soltek motherboards, bad caps and no POST
    replace them all.
    at least everything above 470µ, but if you're at it, you might do them all, since GSC are crap.
    don't forget to reset the CMOS.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • Leung Kai-yan
      • Apr 2006
      • 32
      Dear Friend,
      When I had replaced the great majority of the capacitors of this mainboard, it did a rebooting once every two months. It is completely free of any problem when completely doing the replacement.
      • Leung Kai-yan
        • Apr 2006
        • 32
        Dear Friends,
        I replaced all the capacitors of the above mainboard with the new Rubycon capacitors of MCZ, ZLH and ML Series more than two years ago and the second picture was made several days ago.
          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
          by momaka
          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
          https://www.badcaps.net/filedata/fetch?id=3591771
          https://www.badcaps.net/filedata/fetch?id=3591772
          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
          https://www.badcaps.net/filedata/fetch?id=359177...
          03-12-2025, 03:42 PM
        • eryjus
          Heathkit IO-4205 Power Supply Caps
          by eryjus
          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
          05-10-2023, 11:21 AM
        • Paxman_Swede
          Identifying caps on an old Zoom 9000
          by Paxman_Swede
          Hello!
          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
          I have studied the board and...
          01-14-2025, 09:51 AM
        • captain150
          Help with switching power supply caps
          by captain150
          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
