So, I picked up a used 70" Sharp Aquos LC-70LE600U set that failed due to an LED lamp error. The front status LED flashes a slow on then off. The set will startup in service mode and the lower section of the right side of the display has a dark back-light section. I just cracked it open and will start taking some measurements when I get more time. So far the output fuses on the main board seem to be fine. My fear is that there is a bad LED edge strip...I really don't want to have to remove the display but it might come down to that.
I will attached some pictures and the service manual. Any advice on things to look out for is welcome!
