alienware m14x r2 almost dead . 3.3v 5v always problem
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    hi, i was using my m14x r2 (that is my second laptop) for internet navigation. after a bit of watching tv, i went back to pc and it was dead. tried power on but nothing. i noticed it try to power on, but nothing more then a blink led.
    i disassembled it and after a while i discovered that if i touch with finger with some umidity the board near 3.3 and 5 volt regulator and press power botton, pc power on ok. so i bought the schematic on the internet (didnt find it anywhere) and noticed that on pu201 pin 8 is 5volt when off and if i press power botton it reach almost 8 volt, and pin 22 is 8volt and if i press power botton it goes to 11 volt.
    i share the schematic with you
    edit: chip is rt8205lzqw EM FB 60A any chip that is compatible with this one ?
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: alienware m14x r2 almost dead . 3.3v 5v always problem
    i did some test:
    when i plug-in dc psu, i have 3.3 and 5 volt for about 3 seconds, then they go both to 0volt. when i press power botton, i have 3.3 and 5 volt for 2-3 seconds and again 0volt. sometimes pc start ok, and cant figure out why.
    cant edit previous post, but the 2 pins i mentioned were 9 and 22 instead of 8 and 22.
    all voltage seems ok.
    i pass all pu201 solder joint again, but still same result.
    • atsio
      • Oct 2013
      • 819
      • Greece
      Probably problem with fets of PU201, replace all fets and to be on the safe side and PU201
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        tnx for reply. while measuring pin 7 of pu201, psu went off. now everytime i connect psu it come off like short on vin rail, but if i measure pin 16 of pu201 that i have removed there is no short and seems no short in any coils...
        edit: no short on any 3.3 and 5v fets.
        • atsio
          • Oct 2013
          • 819
          • Greece
          You mean the pad of pu201. You have removed pu201 and ALL FOUR FETS and you have short on the vin rail. If not, remove all and check again.
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            i have no short on vin rail..... if i measure pr101 all is ok, no short. with multimeter in diode mode i have 100, while a short is 001 002.
            edit: no short also on pq101
            edit: ok strange thing:
            i have removed pq101 and psu doesnt come off annymore. measured pu101 pin 24 and i have 19volt. no 19 volt on pin 16 of pu201 (strange).
            also when i remove pq101 and i have light on psu, if i measure pin of pq101 i have no voltage....
            edit 3:
            ok i removed pq102 and pq101 was ok, so remove pr101 and psu was still ok. without pr101 i have no volt on pin 16 of pu201. i have also removed pu101 before removing pr101, but with pr101 psu went off.
            withour pr101 i have 19volt one side 0.5volt the other.
            • atsio
              • Oct 2013
              • 819
              • Greece
              100 ohm on 19v rail is a short. Remove the fets of pu201.
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                not omh, im in diode mode.in all other short i had, a short in diode mode was a 000 001 002, while here i have 100, but something is weird because psu shut down.
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  Even in diode mode 100 is a short on 19v rail
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    ok, removed 4 fet pq201,pq202,pq203,pq204 and put back pr101 and still short...
                    edit: forgot to say that yesterday without cpu, pc power on, while when i put cpu in socket it wont start. tryed also with another working cpu but was the same.
                    if it is short in cpu rail, i have to remove pl710-, pl711, pl712, pl713 to isolate short ?
                    edit: removed pl710-, pl711, pl712, pl713 still short on 19volt rail
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      when i encounter that its usually shorted cap or mosfet near cpu rail
                      Im Back... sort of...
                      • dellxps15
                        • Feb 2014
                        • 1598
                        • italy
                        ok after remove some pj and pl i isolated short after pl504, so must be or one of these 4 caps or bad gpu..... but bad gpu is strange....
                        edit after try with cpu, i had to remove also pjp503. now pc power on that's at least a good thing :p
                        tryed with ram rtc battery and display and it display the alienware logo
                        • dellxps15
                          • Feb 2014
                          • 1598
                          • italy
                          isolated short. both fets of gpu were bad. pq505 pq506 si4634 and si4172. now i need to order them and hope all will work fine like normal
                          tnx for help
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            glad to hear that
                            • dellxps15
                              • Feb 2014
                              • 1598
                              • italy
                              hi all and happy new year. i got the 2 mosfet some days ago and also board reballed. now pc power on, but sometimes it didnt show dedicate vga in bios a,d when it see dedicated nvidia card it start load windows ( i have 1.5volt on gpu rail) but after a bit that volt drop to 0 and i have black screen.
                              if i power pc with battery only ( that disable dedicated nvidia ) pc power on just fine with only intel and im able to log into windows.
                              also if i connect hdmi or vga to pc, they never show picture even if i disconnect lvds cable. bad bga or what sould i check ?
                              edit: if i plug battery only, pc is able to log into windows and also hdmi and vga works perfectly.
                              most of the time the discrete is not shown in bios and pc power on ok with only intel vga. when pc see the discrete it wont log into windows... giving me a black screen. now big problem is make discrete shown every time i have battery + psu.
                              • dellxps15
                                • Feb 2014
                                • 1598
                                • italy
                                i have reprogrammed bios from windows with official dell latest bios. pc power on but sometimes doesnt show dedicated vga.
                                where i have to look ? 1.5volt gpu are present.
                                • dellxps15
                                  • Feb 2014
                                  • 1598
                                  • italy
                                  update: i have ordered a new bga for nvidia gfx ( 50$ ) and soldered it. now gfx is always detected from bios. windows 10 load fine with integrated vga, but if i try to install nvidia driver, pc freeze. i noticed that pq505 voltage goes from 1.5 volt to 0 volt when image freeze ( i can still move the mouse). also 1.05 volt gpu goes to 0.
                                  if i look at pq505 pin 4 that goes to 0, i see that it is related to vram power. so first short was in vram ?
                                  ps: if i dont install nvidia driver ( i have nvidia generic vga with error code 31 in device manager) i have stable 1.5vsdgpup and 1.05 volt too. anso 3vsdgpu are ok. but if i try install nvidia driver, 1.5 and 1.05 volt goes to 0.
                                  edit: measured vga_core and when pc is without nvidia driver it has 1.1volt on pl602 pl603 pl604. if i install nvidia driver voltage drop to 0.84volt.
                                  if i remove vram jumper pjp503 that supply 1.5 volt for discrete nvidia vram , pc works fine and detect only intel graphics.
                                  when i open gpu-z with all pc and component installed, i have 384 shaders detected and 3gb of vram detected too. just pl602-604 are very hot. i wouldnt think of bad bga, since i have bought a new one....
                                  • dellxps15
                                    • Feb 2014
                                    • 1598
                                    • italy
                                    anyone with boardview for that laptop - mainboard ?
                                    • dellxps15
                                      • Feb 2014
                                      • 1598
                                      • italy
                                      ok, i decided to get another m14x r2 faulty mainboard to give it a look. after some work on it now, on this one, i have green light if power on with battery only and red light if i put power supply. in both case it power on and stay with black screen for 70 seconds. then display come on and is fully working. both vga works on windows 10. what can be that 70 seconds before display comes on? bad intel h77 chipset ?
                                      on the other dell, why it wont install nvidia card ? if i boot on dos, nvflasher can see nvidia 650m, but as soon as i install drivers it stop working.
                                      on both pcs i have tried with unlocked bios:
                                      on that second working when i upgraded bios , it stop working and power off just after the 70 seconds.
                                      on the other one it start only if i put integrated graphics only.
                                      any help would be appreciated, but tomorrom in finally going some days on holidays , but still read tht forum these days in the ope of some clue and reply.
                                      edit: attached unlocked bios dump and ec bios dump.
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1490
                                        • portugal
                                        Here it is
                                        • RAMeow
                                          Alienware M17 R5 AMD DEAD ISH BIOS
                                          by RAMeow
                                          Hi all! Been a long time lurker here! Hopefully I can get some assistance / guidance for this issue I'm stuck with.
                                          Have a (DELL) Alienware M17 R5 (ST: 4LN41Z3) that windows started a bios upgrade and never completed!
                                          It went through the restart then black screen. power button then blinks 3,6 - "System BIOS Flash incomplete" is what the service manual / support shows.
                                          basically it killed it and attempts to use the "dell reflash procedures do get a Alienware logo flash but then hangs.
                                          I purchased a few programmers from the listed suggestions...
                                          04-21-2025, 01:00 AM
                                        • Tend0
                                          Alienware 17R2 dead, no power, no charging
                                          by Tend0
                                          I just received an Alienware for repair, the pc seems to have been tweaked before.
                                          I did an inspection and some components are missing. the pc does not turn on, after the tests on the main rack I have the 19v from the charger to the drain of the pq707 and to the pq701and :
                                          PQ707 : Source= 17,46V ; Gate=19,52V ; Drain= 19,52V
                                          PQ701 : Source= 17,46V ; Gate=19,52V ; Drain= 19,52V
                                          PQ702 : Source= 17,46V ; Gate=14,18V ; Drain= 16,96V
                                          PR702:16,96
                                          I don't understand why the voltage at the main line is 16.96.
                                          Is it because missing...
                                          02-21-2023, 01:03 PM
                                        • kain0007
                                          Alienware X15R2 P111F black screen after updating windows.
                                          by kain0007
                                          Hi Masters.
                                          I have an Alienware x15R2 laptop that went black after updating Windows.
                                          Could someone help me repair my bin?
                                          Alienware X15R2
                                          ST: 1CJY6M3
                                          Thank you very much for your support....
                                          10-09-2025, 02:20 PM
                                          Alienware 13 R3 Notebook Specification for Upgrade or Repair
                                          This specification for the Alienware 13 R3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13 R3 boardview and 13 R3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 13 R3 Notebook...
                                          09-06-2024, 06:42 AM
