superflower leadex silver - wtf 12mV ripple on a crapxon psu?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3259
    • Singapore
    well i came across a review (NOTE: link is in korean. just look at the pictures displayed) by a korean site called playwares who seemed to attempt to review a superflower leadex silver psu ala johnny guru style.
    if u skip forward to page 3 where they open up the psu. i think i notice what looks like capxon on the modular panel, ncc smq on the primary input side and almost all black and gold capxons or g-luxons on the secondary output side, save for one lone ncc kze amongst all the crap caps.
    and it gets shocking, on page 4 where they try to put it on an oscilloscope, it measures just 12mV ripple as the worst case ripple scenario.
    i think me and many members here (esp pentium4) will find it really un-un-un-unbelievable that a psu stuffed with crapxons or g-luxons can produce just 12mV ripple. i dont know what their oscilloscope was smoking to get that kind of ripple reading. any pros can advise if their oscilloscope is a reliable brand/model or kaput? or if its just "dapun" (bad) as they say in korean. is that review accurate or were they just paid off to cough up some random positive figures, look like some johnny guru wannabes and take people to be "baboos" (fools) as they say in korean?
  • mariushm
    • May 2011
    • 3799
    Re: superflower leadex silver - wtf 12mV ripple on a crapxon psu?
    It is possible.
    Even capacitors made by Capxon can achieve the "performance" Japanese brands like Nichicon or NCC or Rubycon can do when they're new, they're considered bad because they're not as reliable as Japanese brands (they degrade in time, their performance can decrease).
    If the power supply is well tweaked and uses sense wires to measure the voltage at the connectors, then it's quite possible to have 12mV ripple.
    The psu seems to have polymer caps on dc-dc converter boards that produce 5v and 3.3v, there's some polymer capacitors on the modular boards, I also see a design that's well layed out for air cooling which is done with a 140mm fan so quite adequate.. the temperatures show maximum 56C so overall it seems like no reason to worry those Capxon capacitors will fail soon.
    Secondary side is also a synchronous design with mosfets to do the 12v, so that also helps with regulation, it's not the old boring diode rectifier design.
    The 750w uses the same platform only some capacitors are changed to NCC, but you can see on the modular board Capxon electrolytics and polymers are still used and it's acceptable as the review says: https://www.techpowerup.com/reviews/...50F14MG/4.html .. and they get the same small ripple values.
    • Stefan Payne
      • 1267
      That are CapXon, probably GF Series (seems like it).
      And I don't see anything wrong with it. There are at least 6 caps in parallel, there doesn't seem anything hot close to that. Seems like a great layout that could make the components last a long time...
      It's not a shitty design like FSPs GHN and HHN witch look like that:
Name:	DSC_3532 - small.jpg
      That's a good example for a design that needs great caps because sometimes there's just no other cap that shares the strain of the circuit, sitting next to a damn hot heatsink and so on...
      With this Super Flower Design, the caps are pretty far from hot areas....
      Looks pretty good. The only question remaining is how much ripple current do those caps have to endure?!
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • Antonynl
        What are typical ripple voltages on a laptop motherboard?
        by Antonynl
        I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
        So I have two questions:
        1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
        2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
        Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
        12-09-2022, 06:51 AM
      • Ady2017
        Is there a manufacturers tolerance for ripple?
        by Ady2017
        Hi all
        I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
        As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
        The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
        11-13-2021, 11:46 AM
      • Antonynl
        Lenovo 530 Vcore : what is the maximum ripple?
        by Antonynl
        Hi
        I have a Lenovo 530 14ikb i5 8th gen motherboard and it fails to start Windows: it normally dies after I try to load Windows. Getting into bios screen works fine.
        Made some measurements and I suspect that there is to much ripple on the 2 Vcore coils.
        What is normally the maximum ripple allowed on say any of the power supplies? A few %??
        The ripple is on both Vcore as outlined in red in attached photos.
        Could be a bad driver?
        Cheers...
        04-29-2023, 04:59 AM
      • sumilumi
        700mv ripple on Akai Sampler linear supply
        by sumilumi
        Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
        I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
        On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
        01-02-2022, 10:12 AM
