Delux ATX-450W extreme upgrade
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    I helped a friend of mine build a nice new computer a couple months ago. It's got an AMD A10-7850K, 8GB DDR3 1866, a nice Gigabyte mainboard which i can't remember much about other than i recommended it to him and it's got plenty of overclocking options, and a 1TB HDD. Basically a good all-round computer.
    He decided to keep his old PSU for a while because "it was only used for a few months in the old system". One of those "Delux" PSUs with the green label. Mediocre at best, motherboard killers at worst... The fan was already sounding bad even though there was hardly any dust in it. We even did some overclocking and it held up, but i wasn't putting my hopes up.
    I lent him my old hard drive for a while until he bought the 1TB drive. When he bought that, i suggested that it might not be a good idea to leave that much data at the mercy of that pile of turd, since he intends on working on that computer (Autocad, 3ds max and Photoshop). When he showed me some of the units he was looking at, i proposed that instead of him spending $20-$25 on another PSU that will still be a piece of crap, he'd be better off paying me that to upgrade his current PSU to better parts. And here we go.
    The PSU looked like this: No input filtering other than two little Y caps, 470uF main filter caps, 13007 main switchers, EI-33 transformer. The secondary was absolutely pathetic. 20A schottky diodes for 5v and 3.3v, and a *gasp* 12A fast recovery on 12v. Capacitors were all Asia'x, 1000u + 470u on each rail, and only 3.3v had a (sad looking) pi coil, others were simply jumpered. Also interesting to note is that this PSU does not have a 3.3v sense wire. The circuit for it is still there, they just couldn't be bothered drawing one more wire. To compensate for that, the 3.3v rail sits a bit high at 3.42v with no load.
    5v and 3.3v each got a 30A schottky, and 12v got 2x 20A schottky in parallel. I had to hack the PCB a little to fit the second 12v rectifier, but nothing major. I also found a larger heatsink of the same shape for the secondary and used that to install the new secondary parts.
    All pi coils were installed and the output filter toroid for 5v and 12v was replaced with something more appropriate. Interesting to note is that i checked the two toroids with my LC meter and they registered the same values. Of course, the larger one will have more current carrying capacity before it saturates. The coil i installed used to have a -5v winding as well - i have unwound that before installing it.
    The primary side was left alone, other than the addition of an input filter coil. I only have a few 13009s left and i would rather keep them for more profitable projects. Capacitors were basically a grab bag, it was what i had around. A mix of Panny FL, Sanyo WG and an odd "Seacon". I had to drill some extra holes to get them all to fit.
    5vsb got two 1500uF 6.3v Sanyo WG. 3.3v got one 3300uF 6.3v Sanyo WG and two 820uF 6.3v Panasonic FL after the pi coil, 5v got one 3300uF 6.3v Sanyo WG and that Seacon 2200uF 10v (had that cap lying around since forever, can't remember what it came out of), and 12v got 2x 1000uF 16v Panasonic FL and another 1000uF 16v Panasonic FL after the pi coil, and one of the Asia'x 1000uF 16v caps originally on the 12v rail got moved on the -12v rail.
    All those motherboard-grade caps in there did make the PSU whine under certain loads, so i had to do a couple slight changes to the feedback circuit. YMMV.
    To finish, two more SATA+molex chains were added and the fan was replaced with a Yate Loon 2800rpm one. I also installed a temperature control circuit so it doesn't spin full blast if it doesn't have to. The ugly black thing with two blue wires coming out of it in the last pic is a thermistor wrapped in a lot of heatshrink.
    And that's how i turned a pile of turd into something that is actually recognizable as a PSU. It may be even 80-plus worthy.
    A working TV? How boring!
  • mockingbird
    • Dec 2008
    • 5488
    Re: Delux ATX-450W extreme upgrade
    You certainly gave that a unique touch.
    When you say input filter coil, you're talking about that choke, right? What do chokes do exactly? Do they sit between the rectifier and the input caps or before them entirely?
    Great job. By the way, junky fans can be made to run very well with a good re-greasing. The only thing that I don't like is when the fan has no rubber plug on the hole, because then the dust gets in.
    But if the stickers loses its adhesiveness, I just use some rubber cement I got from the dollar store. It's also good for re-applying rubber feet to routers or modems if they fall off.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      What can I say?
      Now, it's a "Super Delux."
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        • Romania
        Good job on that Delux!
        Might upgrade the rectifiers on my Delux since it's powering a Athlon 64 x2 and it quite gets hot. Mine's a Linkworld inside btw. Also,I installed a Delta fan in the place of the old one.(Ruilian Science)
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          It is called a "common mode choke", it sits in the AC input, before the rectifiers. Both line and neutral pass thru it. You can check out its operation in detail here. File is also attached in case it moves somewhere.
          We had oiled the fan before. I still didn't like how it sounded. I usually use silicone grease, but we didn't have any on hand at that time. Maybe i will try the grease and see if it gets better.
          • Majestyk
            • Nov 2013
            • 96
            ..., and one of the Asia'x 1000uF 16v caps originally on the 12v rail got moved on the -12v rail...
            I would kick this one out of the PSU, Asia´X Caps are made by Fuhiyyu.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              It's the -12v rail which is unused nowadays. Could care less even if it bloats. It's not in a hot spot either so it will be fine.
              Friend said he installed it back in his computer today. He told me he thought at first that the fan wasn't running. After a few hours of gaming he says it sped up a bit but the air coming out is just barely warm. This is running the 7850K at 4.4GHz full time, turbo disabled.
              So i declare this one a success.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Wow, awesome job! That must have been fun to work on.
                NICE! was the -5V winding the only difference between the two?
                With the higher efficiency, you could probably get quite a bit more out of those 13007s and 33 transformer.
                Where's the temperature control circuit? What method did you use?
                Did you change out that 27Ω(?) resistor on the 5V so it doesn't cook the Seacon cap?
                Yeah I'd say it was definitely a success
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Yes, For the temperature control circuit i just used what was silkscreened on the PCB in the first place. A 1 amp NPN transistor, a thermistor and a resistor.
                  I did not change or move any minimum load resistors, couldn't be bothered.
                  Btw, there is one deliberate mistake that i have left in the pictures. Anyone noticed it until now? It has been changed before i put everything back together. Hint: diodes.
                  • Wester547
                    • Nov 2011
                    • 1268
                    • USA.
                    The 45V reverse voltage spec is too low for the +12V output of the half bridge topology? Regarding the two MBR2045CTs, I mean. That would be my guess.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Exactly. I did actually test it like that and one of the MBR2045s failed short after a few hours. They were replaced with one 20100 and one 3060 in parallel. With 50A worth of diodes, this isn't gonna have 12v capacity problems, ever.
                      • Wester547
                        • Nov 2011
                        • 1268
                        • USA.
                        As far as I can recall, the different voltage drop characteristics of the two rectifiers can possibly cause thermal runaway (if not that, derate the current capability) since they're in parallel. But with good cooling and heatsinking, you could keep that under control.
                        • everell
                          • Jan 2009
                          • 1514
                          Your Delux power supply looks like some I-Micro power supplies I recently worked on. They also required some "unique" improvements. Would you say that Delux and I-Micro are the same in Romania? I have never seen a Delux brand in USA.
                          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                          • Khron
                            • Sep 2006
                            • 1350
                            • Finland
                            For all we know, i reckon they may as well be the same OEM
                            But then again, who can know how many Chinese factories churn out tons & tons of these cheapos based on that same "archetypal" design?
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Good job!
                              I thought something seemed odd there! :P
                              Did it blow the switching transistors when it shorted?
                              Originally posted by kaboom
                              What can I say?
                              LOL You guys are too funny! xD
                              -Ben
                              Muh-soggy-knee
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                No. It actually has working overpower protection, however far-fetched that might sound.
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1866
                                  • Romania
                                  Wonder what happens if you put some 13009s in it.
                                  At least my Deer came with 13009s.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    With that much beef on the secondary, 13007s will suffice for the job.
                                    I have pulled 650W continuous at 40C ambient from a pair of 13009s, with efficiency of ~84% (over 90% at 350W). It's all in the output rectifiers.
                                    • Dan81
                                      SNES-powered
                                      • Oct 2013
                                      • 1866
                                      • Romania
                                      Heh. I just did one exactly like this today.
                                      Some of the stuff I have done for now (it's still WIP) :
                                      ERL-35 transformer from a dead Kaisen
                                      Complete input filter
                                      PI coils
                                      Yate Loon fan (the old one was partially seized)
                                      To be done:
                                      Balance the amperage of each rails for 12v-heavy operation (16A for 3.3 and 5v rails and a BIG load of amps for 12v? 30A for 12v sounds like a good thing. (though 20A isn't bad either)
                                      FULL RECAP (including primary)
                                      13009 transistors (I have a pair of them,gotta test them though - might consider TT2194s as well)
                                      Newer case with 120mm (hope I can get one of those uber-crappy 460W LPK19-30 PSUs) fan - probably going to use a Raidmax LED fan for it.
                                      Connectors: 1x 24 pin ATX detachable,2x SATA,2x Molex,1x Floppy,1x ATX12V P4.
                                      Main rig:
                                      Gigabyte B75M-D3H
                                      16GB DDR3-1600
                                      Delux MG760 case
                                      • pdavid
                                        • Jan 2011
                                        • 279
                                        • Hungary
                                        These generic PSUs are relatively easy to "upgrade". Fit a center tapped EI/ERL core 39 or 44 size main transformer, 15Amp main switchers to experiment with the circuit's limits.
                                          Lenovo ThinkPad X1 Extreme Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Extreme Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Extreme boardview and X1 Extreme schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-07-2024, 06:31 AM
                                          09-07-2024, 05:00 AM
