hp pavilion 14-n007ax bios
  • smali
    • Sep 2014
    • 287
    • Pakistan
    any one please bin bios file for...
    DA0U93MB6D0 REV D
    HELP PLEASE
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp pavilion 14-n007ax bios
    dump your old bios and save or post here
    there are 2 ver in official bios updates in hp website
    exact version can be determined by looking in dump by hex editor
    Im Back... sort of...
    • smali
      • Sep 2014
      • 287
      • Pakistan
      Thanks for your response,
      The old dump is not available because the chip write with wrong file by a technician, and didn't backup the original.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        one of files above should work, but you will have to fix dmi data with that odd hp tool
        • smali
          • Sep 2014
          • 287
          • Pakistan
          i test the both files but did not work,,,, the 3.3v is fluctuation on bios chip pin8,7,3 after pressing pwr switch like on/off may be chip faulty..what you suggest ?
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            you have a working dump here, but i cannot download
            http://*******/viewtopic.php?f=53&t=5916&start=280
            • nazrul145
              • Jan 2014
              • 333
              • BD
              Check it.
              • smali
                • Sep 2014
                • 287
                • Pakistan
                Originally posted by nazrul145
                check it.
                thanks but did not work.
                • smali
                  • Sep 2014
                  • 287
                  • Pakistan
                  Any one have working dump?...please
                  • smali
                    • Sep 2014
                    • 287
                    • Pakistan
                    Check it.
                    after flashing this file now charging battery light on power on/off ok 3v, 5v, 1.5v,1.8v,.8v on cpu 02 coil are ok but no display the missing voltage are on two coil one which is driving by ic ADP3211 i think this is GPU voltage is missing .
                    the key board Caps-lock light is blinking and wifi red light is continuously on.
                    so what you experts are advise and i have no schismatic for this,if any one have please share.
                    • dj_ricoh
                      • 2073
                      • uk
                      How many blinks?
                      • smali
                        • Sep 2014
                        • 287
                        • Pakistan
                        Originally posted by dj_ricoh
                        How many blinks?
                        continuously
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          @smali
                          with my bios files it would not turn on at all? corect?
                          @nazrul145
                          did your file came from dump read from laptop or web update
                          comparing your file with mine only 100 first bytes are different, rest of file is the same, but those first 100 bytes are DMI data that should be fixed with HP tool
                          you can try mu new files if you like
                          there are two versions of bios, probably UMA and DISCRETE... if you flash discrete bios to uma it will blink error for vga cos uma is integrated hence it could not be detected... those may be your blink codes
                          • smali
                            • Sep 2014
                            • 287
                            • Pakistan
                            Dear ala_borbe,
                            first of all i am very thankful of you on the cooperation.
                            According to your first provided bios file are ok but that was my fault when i flashed your bios file i check the laptop on adopter only and not connected the battery , so the voltage were fluctuating on only adopter without battery.
                            but when i connected the battery with adopter the result as i said in my previous post.....
                            "charging battery light on power on/off ok 3v, 5v, 1.5v,1.8v,.8v on cpu 02 coil are ok but no display the missing voltage are on two coil one which is driving by ic ADP3211 i think this is GPU voltage is missing" and also FAN spinning fan continuously.
                            Now the result are same of yours both bios file 02169F16 and the nazrul145.
                            i also write 0216Df16 but it is very abnormal compare to the 02169F16.
                            • ala_borbe
                              aka Donald
                              • 1625
                              • Malta
                              ok, thx for info
                              problem you have is not bios related
                              • smali
                                • Sep 2014
                                • 287
                                • Pakistan
                                @ ala_brob..can post the link hp offical site for bios?please
                                • ala_borbe
                                  aka Donald
                                  • 1625
                                  • Malta
                                  http://h10025.www1.hp.com/ewfrf/wc/s...oduct=5450114&
                                  choose os and scroll down to bios section
                                  sp69882.exe is the file you need
                                  • makina1982
                                    • Sep 2014
                                    • 4
                                    • Chile
                                    please hp 14 DA0U93MB6D0 REV D Bios
                                    • Nadeem Amin
                                      • Dec 2014
                                      • 33
                                      • pakistan
                                      Thank
                                      • angel-boy
                                        • 550
                                        • Romania
                                        i have a problem with DA0U93MB6D0 REV : D
                                        plug in adapter, no orange light for charging , and no white light , power the bord, no image, fan not spinning.
                                        bios problem ?
                                        • iZakre
                                          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                          by iZakre
                                          Hello everybody!
                                          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                          The thing is that I had installed TeamViewer and could log into the computer...
                                          02-19-2023, 02:27 PM
                                        • bondminer009
                                          Need Bios for Latitude 7650 (No Original / dump bios file)
                                          by bondminer009
                                          Good Evening,
                                          Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                                          Thank You
                                          Salam,
                                          Three
                                          11-12-2024, 07:48 AM
                                        • joshAU
                                          BIOS file for N550JK (original dump attached)
                                          by joshAU
                                          Hi all.
                                          I'm looking for a BIOS file for an Asus N550JK.
                                          I have a Asus R552J, which I believe is identical to the Asus N550JK.
                                          I downloaded the latest BIOS (210) for the R552.
                                          It is named N550JKAS.210.
                                          The BIOS file is however only 6mb in size.
                                          I've read the chip with a CH341A programmer and verified the file.
                                          That file is actually 8mb in size.
                                          I'm wanting to remove the BIOS password from this unit.
                                          It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                                          08-09-2022, 08:06 PM
                                        • adelage
                                          Merge ECS Z77-H2 bios cap file with original dump
                                          by adelage
                                          I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                                          03-11-2025, 03:07 AM
                                        • silverflea
                                          Need Bios MSI B75A G43 Dump File
                                          by silverflea
                                          Hi. I need dump file bios MSI B75A-G43
                                          My bios got corrupted and wont boot, so i need to flash it using Ch341A programmer, but bios file from the official website is to large, so i need bios dump file from working motherboard, or anyone know how to cut the bios size to fit bios chip
                                          Thanks!
                                          08-09-2022, 01:37 AM
