Samsung UN55C6300SFXZA blowing fuses
  • EGreen
    • Dec 2014
    • 33
    Hello, I have a sumsung UN55C6300SFXZA with a BN44-00358B/PD55AF1U ZHS
    Power supply board. The guy I got it from said it just went out one day. When I opened it up I found the ceramic cap in location CP808 had been replaced with a RR 221K 1KV 3D . The original was R 221K 1KV. I don't know if this makes a difference. Looks as if the original one exploded due to the burn spot and smoke residue. The fuses were blown, I replaced them, Unplugged all connectors, powered up 120v ,fuses held, no power at the rectifier,plugged in connector to main board, fuse blew.I'm going to get some more fuses today.When I get back I'll use my limited skills to check some more components.
    What would I look for next?
    I have a mid grade DMM with capacitance testing and I orderd this "Small 12864 LCD Transistor Tester Capacitance ESR Meter Diode Triode MOS LCR NPN (251518131978)" .Don't know if it will work by it's worth a try
    I am not well educated in electronics , Can someone point me in the right direction to learn how to trouble shoot and repair these type of boards?
    I paid for an online site to learn but all I got was links to more paid sites.
    Is there a good source for training on how to troubleshoot and repair these TVs?
    I want to learn about the different sections of these board and how to test/repair them.
  • EGreen
    • Dec 2014
    • 33
    Re: Samsung UN55C6300SFXZA blowing fuses
    These are from Shop Jimmy
    • EGreen
      • Dec 2014
      • 33
      I have 5.2 vdc on pin 16 CNM801. When I jumper to pin 18 pwr on/off both fuses blow immediately.
        There are 4 fuses on the board, which are the two that blown? The main AC fuses?
        • EGreen
          • Dec 2014
          • 33
          Yes ,the other 2 are good
          • freakaftr8
            • Oct 2012
            • 3743
            odd I would look for shorted MOSFETs and me 12 volt and other output voltage circuit in the secondary side of the power supply to start.
            • EGreen
              • Dec 2014
              • 33
              Thanks, I'll Check them out of circuit tomorrow.
                So both 5A main fuse is blown when PS_ON command is inserted.
                That is an active shorts, not static shorts, so we need to find out if there are parts that is now damaged.
                You should check the RESISTANCE on the Source and Drain of the power MOSFETs
                QP801, 802 in the PFC Voltage booster circuits, that cap CP808 is the snubber cap for the Diode DP802, 809.
                QM801, 802 for the VDRIVE SMPS power supply for the LED backlights circuit.
                You will need to look up the info on the MOSFET, look up the spec sheet of the P/N of the MOSFETs to get the pinout.
                  You should build one of this BOX which basically put the 120V lamp in series with the load (the TV or what ever you are working on) to automatically limit the current if there is shorts circuits so you do not keep blowing the fuses and parts.
                  You should also use the GFCI outlet to protect yourself.
                  http://s807.photobucket.com/user/bud...in=true&page=1
                  http://s807.photobucket.com/user/bud...tml?sort=3&o=7
                  • EGreen
                    • Dec 2014
                    • 33
                    Thanks Budm ,Will do tomorrow...I am an electrician and have parts to build something similar to that.
                    • EGreen
                      • Dec 2014
                      • 33
                      I found a shorted mosfet
                      QP802
                      STF13NM60
                      I ordered 4 from arrow and some of the correct capacitors to replace the non-matching one that some stuck in there.
                      I also made a dim bulb tester like Budm suggested. The lamp is in line with the nuetral side of the duplex receptacle to prevent shock from the shell of the socket and the gfi is before the lamp so I can use it for full power.
                      • EGreen
                        • Dec 2014
                        • 33
                        Update, Changed out shorted QP802 and and also 801 just in case. The TV powered up and works fine . The shorted QP802 apparently took out the replaced diode CP808 . Thanks for your help. One more thing, When I first powered it up there was green lines and patches all over the screen. I reset all the ribbon cables in the connectors on the T-Con board and that fixed it...E
                          Well done and thanks for the follow-up on the repair.
                            09-07-2024, 05:50 AM
                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                            by sam_sam_sam
                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                            12-14-2023, 07:45 PM
                          • Sik_6ty_Sixx
                            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                            by Sik_6ty_Sixx
                            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                            02-18-2025, 05:06 AM
                            Surface Mount Fuses Fundamentals Datasheet
                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                            10-07-2024, 06:07 AM
                            09-06-2024, 11:40 PM
