hp pavilion 2000 schematic needed
  • salawayon
    • Nov 2012
    • 568
    • philippines
    Motherboard model:
    NEWTON_CR&HR_HPC
    MV_MB_V1
  • salawayon
    • Nov 2012
    • 568
    • philippines
    Re: CQ58-261SA schematics needed
    The problem with this unit it got no LCD BACKLIGHT. Flex ok and vled voltage is ok. Lcd lights ok...
    • dj_ricoh
      • 2073
      • uk
      its led with on line of pins on the mobo connector?
      • salawayon
        • Nov 2012
        • 568
        • philippines
        Yes. I've checked the cable and it's ok.
        • dj_ricoh
          • 2073
          • uk
          its led or ccfl?
          • salawayon
            • Nov 2012
            • 568
            • philippines
            Sorry i forgot.. It's LED.
            • dj_ricoh
              • 2073
              • uk
              measure the first 3 pin and the last 4 pins.
              post the voltage here
              • salawayon
                • Nov 2012
                • 568
                • philippines
                I've dove that already. At Lcd connector pins 2,3,4 got 3.3vdc and at pins 38,39,40 got 5vdc. Pin 36 (backlight ON) no voltage is present when the unit is ON. Pin36 line from lcd to mainboard connector is not broken.
                • salawayon
                  • Nov 2012
                  • 568
                  • philippines
                  I'm requesting for a schematics in order that i could see what parts should i check first.
                  • dj_ricoh
                    • 2073
                    • uk
                    take a photo.
                    no fuse around?
                    • ranjanlaptop
                      • Dec 2013
                      • 207
                      • india
                      part no 688018-001 NEWTON_CR&HR_HPC MV_MB_V1
                      • ranjanlaptop
                        • Dec 2013
                        • 207
                        • india
                        Re: hp pavilion 2000 schematic needed
                        please give me the schematic
                        • aanan
                          • Dec 2010
                          • 222
                          • India
                          check this.
                          • ranjanlaptop
                            • Dec 2013
                            • 207
                            • india
                            this is not the same
                            • razamominbhat
                              • May 2015
                              • 4
                              • india
                              cq58 2nd generation mother board circuit needed
                              • swanand
                                • Dec 2011
                                • 51
                                here it is
                                • rewanco
                                  • Nov 2015
                                  • 21
                                  • syria
                                  Cq58-281er schematic
                                  plz i need
                                  newton_cr&hr_hpc mv_mb_v1 e162264 schematic
                                  • rewanco
                                    • Nov 2015
                                    • 21
                                    • syria
                                    Re: Cq58-281er
                                    up
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Re: Cq58-281er
                                      i think not available but posting a schematic which is very close to your requirement. See if it helps
                                      • fyaagoub
                                        • Dec 2016
                                        • 269
                                        • maroc
