Samsung LN55B650T1FXZA 8 blinks
  • kevinm34232
    • May 2012
    • 1884
    I haven't opened this one up yet, but when plugged in the red standby light comes on as normal.
    When you press the power button, it starts blinking 8 times, with the 8th blink being longer, and then repeats.
    I didn't see anything about blink codes in the SM, does anyone know?
  • kevinm34232
    • May 2012
    • 1884
    Re: Samsung LN55B650T1FXZA 8 blinks
    I unplugged the main board from the PS board and PS turns on, and back light comes on. 390V at main caps, all other voltages look good. Main board again?
      OK, so far your power supply and inverter are OK. Try disconnecting the LVDS cable to the T-CON and see if you get difference blinking LED.
      • kevinm34232
        • May 2012
        • 1884
        Tried that already no difference.
        • kevinm34232
          • May 2012
          • 1884
          So I got a replacement main board, and I have the same exact problem. So if the power supply is good, there is only 1 more board and that is the t-con. Unplugging that board doesn't make a difference though?!?
          • kevinm34232
            • May 2012
            • 1884
            Is it possible that this main board needs a signal from the t-con board to work?
            • kevinm34232
              • May 2012
              • 1884
              Well I had the known main board from the 65" model and the 55" TV will power on, not completely but enough to show the 2nd main board was bad too.
                I am not sure if Samsung uses error signal from T-CON or not, try disconnecting the flat cables between the LCD panel and the T-CON board next, otherwise like you indicated, you only have the T-CON to try next.
                  09-07-2024, 05:50 AM
                • Nairolf
                  Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                  by Nairolf
                  I have a Samsung DM32D display.
                  When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                  Here’s what I have tried so far:
                  1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                  2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                  3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                  From these tests, I suspect the problem might be on the mainboard. Could anyone...
                  08-24-2025, 03:47 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
