required schematic hp mini 110-3107TU
  • sanehdeep2012
    • Oct 2013
    • 139
    • india
    Dear all , hello to every body here
    i have received hp mini in dead condition
    * 19V AVAILABLE AT Q17 PIN NO 2,3,4 BUT NO VOLTAGE AT ANY OTHER PIN
    * NO 11V AT BATTERY THAT IS ALSO MISSING
    I HAVE REQUIRED SCHEMATIC MANUAL
    MODEL: HP MINI 110-3107TU
    WRITTEN ON PCB:
    AB540 DDR2
    PCB:41-AB5400-E00G
    PWA:40GAB5400-E---
    HannStar J MV-6
    THANKS IN ADVANCE,
    WAITING YOUR REPLY DEAR FRIENDS,
  • sanehdeep2012
    • Oct 2013
    • 139
    • india
    Re: required schematic hp mini 110-3107TU
    bios chip does not having any voltage, so always 3.3v is missing , suspected TPS51610 BUT I DONT HAVE SCHEMATIC SO UNABLE TO TRACING
    PL some body help me to get the schematic
    WRITTEN ON PCB:
    AB540 DDR2
    PCB:41-AB5400-E00G
    PWA:40GAB5400-E---
    HannStar J MV-6
    • sanehdeep2012
      • Oct 2013
      • 139
      • india
      TPS51610 IS NOT FAULTY ITS ONLY CORE VOLTAGE IC,
      ANY BODY CAS SUGEST ME WHICH ONE IC IS ALV 3.3V CHIP IN THIS LAPTOP
      WRITTEN ON PCB:
      AB540 DDR2
      PCB:41-AB5400-E00G
      PWA:40GAB5400-E---
      HannStar J MV-6
      • atsio
        • Oct 2013
        • 819
        • Greece
        Try this
        • khaahk
          • Dec 2013
          • 830
          • Estonia
          It should be Arima 40GAB5400, schematic not available.
          • sanehdeep2012
            • Oct 2013
            • 139
            • india
            Originally posted by atsio
            Try this
            thanks for sending schematic , i will check and revert back soon
            sorry atsio this is not the same schematic
            laptop having only two bga chips
            *cpu = intel Q019C323 SLBX5 N475
            *CONTROLER HUB = CG82NM10 SLGXX
            *I/O (KBC) = ITE IT8500E
            * CPU CORE VOLTAGE = TPS51610
            *BATTERY CHARGER = BQ24745
            *LAN = RTL8401
            I AM FACING THAT ALV3.3V IS MISSING BUT UNABLE TO FIND THE WHICH CHIP IS BELONG TO THAT VOLTAGE
            ANY BODY WELCOME TO HELP ME ON THIS TOPIC ,
            • cyberhack
              • Feb 2013
              • 466
              • Uk
              Here
              • sanehdeep2012
                • Oct 2013
                • 139
                • india
                dear friend id=cyberhack thanks for your response to my post/thread
                but schematic given by you is not the same
                you have given via chip set schematic but i need intel chip set schematic
                *LAN = RTL8401
                pl do some more search , i have also searched over internet and did not find same manual
                i am having 5 schematic manuals for hp mini but all are different ,
                pl help me friends i need this schematic urgently
                • sanehdeep2012
                  • Oct 2013
                  • 139
                  • india
                  tracing through tracks without schematic i found the ALW 3.3v genrated through
                  U6 writtent over chip is
                  DT=CH
                  H1C
                  I UNABLE to recognize this chip no if some body know which is this chip pl reply
                  so that is the chip which is not giving 3.3v so pl help
                  • khaahk
                    • Dec 2013
                    • 830
                    • Estonia
                    It is RT8205EGQW
                    https://www.badcaps.net/forum/showthread.php?t=31273
                    • sanehdeep2012
                      • Oct 2013
                      • 139
                      • india
                      Originally posted by khaahk
                      thanks for your valuable info i will try to solve
                      • sanehdeep2012
                        • Oct 2013
                        • 139
                        • india
                        I HAVE RECIVED DT=CD INSTED OF DT=CH AND INSTED OF 3.3V ALW IHAVE RECEIVED 0.4V IS THIS CHIP IS alternate or not what to do suggest,
                        • sanehdeep2012
                          • Oct 2013
                          • 139
                          • india
                          i am stuck at repair how to get alw 3.3v , pl some body provide the schematic of
                          WRITTEN ON PCB:
                          AB540 DDR2
                          PCB:41-AB5400-E00G
                          PWA:40GAB5400-E---
                          HannStar J MV-6
                          *LAN = RTL8401
                          it is urgent friends please help.
                          • atsio
                            • Oct 2013
                            • 819
                            • Greece
                            Where are you checking for 3.3v alw?
                            • sanehdeep2012
                              • Oct 2013
                              • 139
                              • india
                              sorry for late reply,
                              3.3 ALW AT BIOS CHIP
                              AND at U6 chip Pin no 7 of DT=CH(RT8205EGQW)
                              • sanehdeep2012
                                • Oct 2013
                                • 139
                                • india
                                U6 Chip replaced and now 3.3v is availabe and laptop goes power on but now no display
                                • sanehdeep2012
                                  • Oct 2013
                                  • 139
                                  • india
                                  yes its power on now i have required bios dump for same model:
                                  hp mini 110-3107tu
                                  thanks you all in advance,
                                  • khaahk
                                    • Dec 2013
                                    • 830
                                    • Estonia
                                    From hp site:
                                    • sanehdeep2012
                                      • Oct 2013
                                      • 139
                                      • india
                                      From hp site:
                                      khaahk thanks for sending bios file , after programming and check the device i will revert back
                                      thanks again for your help
                                      • sanehdeep2012
                                        • Oct 2013
                                        • 139
                                        • india
                                        [/ATTACH][/ATTACH]update the bios ,
                                        use both the bios file but same
                                        1.mini110.zip bios provided by bad cap user khaahk
                                        2.second bios taken from fhp-110-3100-f.15
                                        http://forums.mydigitallife.info/pri...pp=40&page=210
                                        system power up by pressing power button,
                                        fan running ok
                                        but no display
                                        pl help me on this problem
                                        thanks to all supporting persons at bad caps
                                        any idea most welcome
                                          HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                                          This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                          HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                                          This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 02:20 PM
                                          HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
                                          09-12-2024, 02:15 PM
                                          HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) ProDesk 400 i5-6500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-12-2024, 03:44 PM
