Dell GX280 PSU dead - Or is it?
  • fuxxy
    • 318
    Just recieved this GX280 desktop.
    Plug in, orange status light on the motherboard. A tap of the power switch results in a momentary "something" happening. Holding down the power button results in action out of the system, but no boot. Swapped PSU with known good replacement and the PC powers on and works normally.
    The next day, I plugged the "Bad" PSU into my tester, and not only did the PSU come on, but it presented all pretty normal voltages! Pic of tester included.
    If I let off of the "Test" button momentarily and pressed again, I got an error of no PS_OK. If I left it off for a few (about 5) seconds, it would come back good again.
    The only known physical problem I can identify is a faulty fan. The question is, what should I do at this point? I'm tempted to hit it with a heat gun and see if anything goes out of spec.
    • 31163
    Re: Dell GX280 PSU dead - Or is it?
    that's an early version of a pile of crap i'v been fixing for someone.
    that ceramic cap infront of the main fet needs to be upgraded to 2Kv or even 3Kv or it will run hot & eventually take out the fet + driver.
    • fuxxy
      • 318
      Can you elaborate a bit on which one is the "main FET"? Also, is 11.2 close enough to -12V? I see only one adjustment POT on this thing and it only changes +5V and +12V
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        The main Fet is the silicon attached by itself to that smaller heatsink, so that little ceramic directly below it
          • 31163
          yea, the light-brown( and gets darker as it overheats) thing infront of the big black part on the small heatsink.
          on the newer active PFC version of this supply.
          [H240AS-00]
          the cap overheats.
          then the fet fails and destroys:
          the fet,
          the fuseable resistor on it's right,
          sometimes the main fuse.
          a fast diode to it's left
          2-3 smd parts under the board,
          and a shitload of stuff on a controller pcb hidden on it's side behind the heatsink.
          these dell shit are a bastard!!!!!
          http://en.community.dell.com/support.../19423875.aspx
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            It looks well built. Hipro? It just looks like the primary heat sink is way too small for that sort of form factor, and that already small heat sink doesn't even fins to help the air flow. I think that contributes to the ceramic overheating. Upgrading the heat sink might be difficult, but maybe adding a FET with lower RDSon would help the heat problem
              • 31163
              it's a very good fet already.
              st w12nk90z
              • fuxxy
                • 318
                As I said earlier, I have two of these, identical. One doesn't work at all, the other works fine, but fan doesnt spin. I'm thinking these rely heavily on active cooling and when that fails, boom!
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5016
                  • New Zealand
                  I had Power_Good signal problems on a SFF GX280 PSU due to a bad PWM controller supply\startup capacitor.
                  -David VanHorn
                    • 31163
                    did you test the fan?
                    if you did, just connect it directly to the supply lines.
                    thermal fan control is a joke in these compact systems - you really need it full-on all the time.
                    • fuxxy
                      • 318
                      The fans on my model are 12V, not sure what the supply voltage is. Both fans' bearings were shot and neither spun at full speed - one didnt spin at all.
                        • 31163
                        did you test them on a seperate supply?
                        there is a speed control circuit on the psu.
                        unsolder the fan red-wire & connect it to where the main yellow wires come from.
                        • fuxxy
                          • 318
                          Thanks for that! The fan control circuit was only putting out 4.15V. The fans on both of these PSU's need to be replaced anyway, I'll connect them to 12V when they get here!
                          • fuxxy
                            • 318
                            Turns out, the problem with one is bulging caps on the motherboard. Fixed those and it worked fine!. I replaced the fan in the PSU and connected it to +12V.
                            The second PSU I'm working on now. I get no response from my PSU tester, next step is testing for 5V standby
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • gugutm
                              Dell Latitude 5410 dead help please.
                              by gugutm
                              hi everyone,
                              need some advice i am not professional just junior , but maybe someone could help me please
                              i have
                              Device : Laptop
                              Brand : DELL
                              Model : LATITUDE 5410
                              Board Number: FDZ41 LA-J371P Rev:1.0
                              i am attaching schematics and board view. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...14#post3484414
                              my problem is its not turning...
                              08-28-2025, 02:24 PM
                            • Francesc V.
                              Dell dockstation WD15 is dead
                              by Francesc V.
                              Hi:
                              A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                              Here are the findings, followed by good pictures. :-)
                              When pluged in, LED3 glows
                              Measuring some voltage in the circuit.
                              Inductors
                              - PL202 has 5V
                              - PL201 has 3.3V
                              - PL300 has 1V
                              V. Regulators
                              - UT30 has 19v as input and 6V as output. It seems ok.
                              - UT27 (same reference as UT30, has no input/output voltage).
                              Thermal find...
                              07-09-2025, 12:12 AM
                            • YellowJacket
                              DELL Latitude 5410 - dead; pwrbtn flashing
                              by YellowJacket
                              Hi folks,
                              DELL Latitude 5410, board number FDZ41 LA-J371P Rev: 1.0 (A00), schematic uploaded in different post, here is the link --> https://www.badcaps.net/filedata/fetch?id=3484415
                              When I connect it to a power ( DELL round charger, or USB-C ), LED on the power button starts flashing white, and the laptop doesn't do anything ( flashing slows for a very brief time in time when I press it, but it continues again ). Battery is not charging. While the charger is connected, I have few voltages present, but some of them are fluctuating, see attached pictures.
                              All I was able...
                              04-26-2025, 07:05 AM
                            • tracks
                              Dell 3080 Micro BIOS dead
                              by tracks
                              Hello all,
                              I have a Dell 3080 Micro with a problem. As it is right now, it seems to be boot looping, maybe... There's no output, just fan on and power led lights up and blinks off every 2 seconds or so.
                              Previous owner told me he bought it with a BIOS password, he tried to use a CH341A programmer with some random test clip and tried to mess with it while it was powered on. Now it won't boot.
                              I tried to dump the bios with an EZP2023+ but I can't get a consistent read. Every time the dump is different, so it's unusable. I think the BIOS chip is fried.
                              04-19-2025, 03:42 PM
