I bought a Samsung UN46D7000LFXZA today. It's about 3 years old and I got it for $40. BUT, it's not working.
The guy said it turns on and off. After looking online to see what the problem might be, I thought I would take
a chance and buy the TV hoping I could fix it.
When the TV is plugged in, it turns on and about 2 seconds later (just as the Samsung Smart TV lights up on the
screen), the TV turns off, then on, and then off. It will do this indefinitely.
This is what I did do far...
I unplugged the little button bar (power, volume, etc) and still the same problem.
I unplugged all the plugs 1 at a time in numerical order (according to the oicture). The only time it stopped turning
on and off was when Iunplugged #3, the ribbon cable going from the P/S to the M/B. (Can it be the M/B causing the
problem?) I unplugged #'s 5 & 6 (going to the screen) and the screen didn't light up, but the power supply still turned
on and off.
When I disconnected the cable from the main board, nothing happened. No clicking, but the P/S didn't turn on either.
I did a visual inspection of the P/S board with a light and magnifying glass and didn't see any problems. (I know Samsung
TV's have a problem with the caps on the P/S board.)
The only thing that isn't normal is a slight discoloration (dark brown from overheating) around the openings in the red circle.
On the plastic behind the screen panel, the part that comes in contact with the back of the P/S board it a little melted. Is it
normal for this to get that hot?
I took off the P/S board and inspected the back, but nothing look out of place. I inspected the M/B, but there really is
nothing to look for on that board.
Any ideas how I can pinpoint the problem to the P/S or the motherboard?
Thanks,
Ian
on and off.
Thanks,
Ian
