LG Flatron W2442PA bad caps?
  • Pimvb
    • Sep 2013
    • 12
    • Nederland
    One of my monitors just went down a week ago [LG Flatron W2442PA]. I used before going to bed, didn't turn it off, and when i woke up i couldn't get it to power up. The power button doesn't light up either. I've switched cables, sockets, the lot. Nothing works, it seems dead.
    I've been reading up on on the topic and found that the most likely causes are bad caps or broken fuse (hence my enrollment on the website). I've read that broken caps can be recognized by bulging tops or leaking 'electrolytes' at the bottom. I opened my monitor to inspect it and found the situation as shown in the attached pictures (specific monitor ID etc also included).
    I'm not an expert but it looks fine to me.
    basically i have three questions:
    1. Do the caps look oke?
    2. How can i test them? (preferably without a multi meter, as i don't have one)
    3. What other causes can there be?
    I hope you can help, all replys are appreciated.
    Regards!
    Pim
  • Rtech
    • Jul 2010
    • 1095
    Re: LG Flatron W2442PA bad caps?
    The second photo(which shows your hand),has two large capacitors on the Right side,and just behind them 4 Diodes in line,and you also show the fuse.The first test,would be the fuse,the second would be to measure the Voltage across those caps,and the third would be to check those diodes.YOU DO NEED A METER,and you can be advised how to proceed when you have use of one !!
    • Uniballer
      • Jul 2013
      • 334
      None of them appeared to be bulged, but they also don't seem to be good brands.
      Desolder them and test them with an ESR meter.
      Start with the fuse. Check it with the ohm meter you said you don't have. Could be a blown diode or transistor, or a bad transformer winding or optocoupler... I find my old Tek 475A analog oscilloscope, which is very easy to float due to its linear power supply, to be the easiest tool for me when diagnosing SMPS failures (it is politically correct for me to tell you not to purposely defeat protective grounding on any equipment).
      Keep in mind that the power supply could (theoretically) be fine, and that the problem could be elsewhere.
      • Pimvb
        • Sep 2013
        • 12
        • Nederland
        Thanks for the feedback guys, going to get myself a multi meter and start measuring
          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
          by momaka
          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
          https://www.badcaps.net/filedata/fetch?id=3591771
          https://www.badcaps.net/filedata/fetch?id=3591772
          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
          https://www.badcaps.net/filedata/fetch?id=359177...
          03-12-2025, 03:42 PM
        • eryjus
          Heathkit IO-4205 Power Supply Caps
          by eryjus
          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
          05-10-2023, 11:21 AM
        • Paxman_Swede
          Identifying caps on an old Zoom 9000
          by Paxman_Swede
          Hello!
          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
          I have studied the board and...
          01-14-2025, 09:51 AM
        • captain150
          Help with switching power supply caps
          by captain150
          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
