Phillips 42PFL5432D/37
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Saw quite a few threads on this TV but not this particular problem. It powers up and the menu comes up very briefly but then immediately fades away. The backlight stays on indefinitely after this happens. It will do this only a couple times before no image shows at all and then it has to cool off for 5-10 minutes to even get that far again. I have attached a video of the problem. The image looks perfect for the second that it shows.
    Capacitors on the power supply all appear to be good
    Thanks as always for any advice.
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Phillips 42PFL5432D/37
    Pictures of the board layout but I'm sure someone else has them on here already.
    • notallbad
      • Oct 2012
      • 1190
      Think its going to be T-Con bd!
      • notallbad
        • Oct 2012
        • 1190
        Remove each of the white ribbon cables going to the panel from the T-Con board in turn, then power up the tv. Of course only half the screen will work!
        Does it still have the fault? With which ribbon cable removed?
        Seems odd both sides go out so worth changing the T-con first!
        Also, strangely enough I recently replaced that exact same board in a TV (Toshiba 42X3031D) just a few days ago with the same fault, as per video, darkness sweeps across the screen but with backlight still on.
        T-Con board : V420H1-C07
        • aaronwt6
          • Apr 2013
          • 855
          • US
          I'll go give this a shot and report back in a few minutes.
          • notallbad
            • Oct 2012
            • 1190
            Sure thing!
            Press 'Menu' button on front/side panel or on remote to be sure there is definately no image shown unless you have an input connected and selected when the tv first comes on.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              Ok. I can take a picture if needed but what I have with the left side is unplugged (looking from the back), is a solid white 1/2 screen and the other side goes from a bunch of vertical lines to a white screen and back. If I change inputs or hit the menu I can see the screen respond by the lines shifting left and right.
              If I unplug the right side only, nothing lights up at all other than the backlight. Regardless I get no picture or menu at all doing either.
              • aaronwt6
                • Apr 2013
                • 855
                • US
                Oh, and I never had anything connected in the first place. Was just getting the menu by pressing the button or changing the input source. I am almost positive its not a screen issue. Guess I could check for sound with the DVD player.
                • notallbad
                  • Oct 2012
                  • 1190
                  Personally I would say replace T-con.
                  How much can you get one for, where are you? in the US!
                  Try fleabay!!!
                  • notallbad
                    • Oct 2012
                    • 1190
                    $18 free shipping in Michigan
                    http://www.ebay.com/itm/T-Con-LCD-Co...item2c6f553527
                    $15
                    http://www.ebay.com/itm/Westinghouse...item4173f17531
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      Yes sir. Southeast Georgia. I found one already for $19.91. This would be the 1st bad T-con I've had out of 20 or so repairs. Hard to go wrong with a $50 TV and $20 for that. I'll report back when it arrives.
                      Oh, and thanks for the help!
                      $18. Sweet. Even better!
                      • aaronwt6
                        • Apr 2013
                        • 855
                        • US
                        $12
                        http://www.ebay.com/itm/Philips-T-Co...item4d0c218586
                        Nevermind. Its plus shipping. I just bought the one for $15. Its close too. 1 day shipping.
                        Thanks again.
                        • notallbad
                          • Oct 2012
                          • 1190
                          No problem.
                          I think replacing the T-con first will save a lot of time troubleshooting and for the sake of $15 and free shipping, see above, it will be worth it.
                          Of course if you have an oscilloscope you could confirm the T-con is faulty with test patterns.
                          Glad to be able to help, hope all is well where you are.
                          • notallbad
                            • Oct 2012
                            • 1190
                            Wow, that was fast, actually a bargain at that price. I actually paid £6 for mine including postage which was a deal especially as it fixed the TV and saved me hours of troubleshooting.
                            • notallbad
                              • Oct 2012
                              • 1190
                              Please, do not forget to report back on the outcome.
                              Is always nice to have an update.
                              Cheers!
                              • aaronwt6
                                • Apr 2013
                                • 855
                                • US
                                Yes sir. Always! I've made sure to do that on every one I've posted about. Should have by Friday at the latest pending the guy's shipping speed.
                                No scope here but that would be a good Christmas Idea. :-) I'd like to start with just a better multi meter than my 'pocket pro' from Home Depot.
                                lol
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  And hopefully it will be sold on Saturday and onto the next one.
                                  • aaronwt6
                                    • Apr 2013
                                    • 855
                                    • US
                                    I'll try not to be TOO optimistic.
                                    • aaronwt6
                                      • Apr 2013
                                      • 855
                                      • US
                                      Well, the T-Con did the trick. Back in business. Thanks notallbad!!
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        Glad to hear its fixed and nice to hear back from you!
                                        Also pleased that I could offer some assistance its not often much.
                                        Keep that T-con, it may come in handy one day, I know its not 100% working but you know the symptoms with this one so may do for troubleshooting in future or even possibly for spare components providing you check them first!
                                        Looking forward to hearing how soon and how much you sell it for, I'm sure you'll be just dying to tell someone.
                                        Heres hoping your next project is as simple and cheap to repair.
                                        Best wishes!
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
