Sanyo DP50747-00 Plasma No Video Good Audio
  • kevinm34232
    • May 2012
    • 1884
    Sanyo DP50747 Chassis 00
    Panel: Samsung S50HW-YD02
    Symptoms: TV powers up and stays powered up, have audio, but no video. Tried to look for a 'glow' but best I can tell there is nothing. It's pretty bright in here so I rolled up some black construction paper and made a tube out of it but saw no change in lighting.
    I did see one or two random lights kinda shoot around the screen for a second on power up.
    I have not repaired a plasma yet and am actually surprised and pleased that this one powers on and stays on with audio. I had a Sanyo 50747-04 before that shut down with a main board PFC and never figured it out.
    This would be my first real attempt at a plasma repair so I'm looking forward to learning more about it...
    I do not have a scope BTW... Thanks!
    Re: Sanyo DP50747-00 Plasma No Video Good Audio
    First step is to measure Vs and Va on the PSU, and compare them to the panel sticker ratings.
    • kevinm34232
      • May 2012
      • 1884
      Sticker:
      VA=63
      VS=205
      Reading off PS:
      VA=63.2
      VS=206
      VG?= 15.05
      Going to eat will be back soon.. Thanks!!
        Good voltages, close enough. There are fuses on the Y-main and X-main. Check those for continuity, and replace them if they have failed. If the TV then fails to power up, or the fuse has failed, you likely have the common 88N30 FET failure; one buffer IC may need replacing too.
        • kevinm34232
          • May 2012
          • 1884
          Both fuses are good. Where are the FET's to check?
            If the fuses are good, it's not the FETs.
            Suspect the control board.
            The LED on it should blink.
            Does it?
            • kevinm34232
              • May 2012
              • 1884
              Was just poking around aimlessly and discovered...
              F5700 is open..
              R5009 reads about 40k ohms..
              • kevinm34232
                • May 2012
                • 1884
                Yes LED blinks on control board
                  It looks like C5708 is bulging to me.
                  • kevinm34232
                    • May 2012
                    • 1884
                    You're right it's under the heat sink but it is bulging (c5709). F5700 has 1A LF (Littlefuse) on it, and R5009 has 4 bands, brown, black, yellow and gold and resisitor is cyan in color. Can you give me possible replacements for the fuse and resistor??
                    Is it likely to just be those components? Did not find any replacement Y Mains with a quick search.
                      I've done the 42" of this chassis (Samsung branded though) and had the same cap bulging in a different area, it causes the Y-Main to stop working, and give you no image at all. 100uF 50V, I guess?
                      Replace the fuse with any 1A through hole picofuse; what rail does it connect to? Probably for the 15V rail.
                      • tocold4u2
                        • Dec 2012
                        • 284
                        • usa
                        10x10k=100k5% brown=1 blk=0 x yellow =10k gold= 5% i think this is right but ask others to make sure
                          Yeah I think it's 100k too. 40k is in circuit. It's probably fine.
                          • tocold4u2
                            • Dec 2012
                            • 284
                            • usa
                            i got a pk of resistors and it shows on the back how to figure them,,,,,,,which is helpful!!
                            • kevinm34232
                              • May 2012
                              • 1884
                              Without pulling it out it looks like its a 25V 680uF cap.
                                The one I replaced was 100uF 50V, but they may have changed the design.
                                Replace the fuse.
                                Replace that capacitor.
                                See if TV works again.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  http://www.diyalarmforum.com/4-band-resistor-calc/
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Replaced fuse F5700 (Pico Fast 1A 125V) and capacitor C5709 (680uF 25V), TV working now, thanks Tom!!
                                      So, in the end, it wasn't too difficult was it?
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Not this one at least, nothing compared to others I've seen here. I still have 1 more big Samsung in the car tho!
                                        • chazh
                                          LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                                          by chazh
                                          This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                                          I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                                          The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                                          09-01-2025, 08:56 PM
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                        • KYBOSH
                                          VIORE PDP4210EA Plasma TV 42 inch - No Video on DVI
                                          by KYBOSH
                                          Got my hands on an relatively unknown TV brand about two weeks ago.
                                          I certainly hadn't heard of it before.
                                          Previous owner didn't give a description of what was wrong and when I got it the back cover was already off.
                                          I put it on the back burner until I had so spare time to look it over.
                                          Today was that day.
                                          I plugged it in and was surprised to see that it started up without any issues.
                                          This is an older TV and the most modern video input that it has is DVI.
                                          I was scrambling to find a DVI connector or adapter as I haven't fooled with that...
                                          01-27-2023, 08:19 PM
                                          GeForce RTX2080 Super Aero video gaming card issues help need
                                          by sam_sam_sam
                                          This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                          Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                          05-07-2023, 08:12 AM
                                          HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                                          09-06-2024, 06:20 AM
