Greetings,
I have an ABIT AN8 32X motherboard with one bad cap and I think maybe more. Right now after you push the power button the system will either not even turn on, or after it turns on will turn off by itself after about 30 to 60 minutes. In the picture I've attached I can see that its got 1 bad capacitor from what I can see marked as KZG 6.3v 2200uF. Should I replace all the KZG caps? Could they be bad even if they don't show failing signs? I have been reading seeing that the Rubycon should still be ok? I'd just replace the board because I hear that the chipset this board uses (NVIDIA nForce4) could also fail, but I've come into a money crunch and am trying to be as frugal as possible. Thank you all for your help!
