What would cause a dim display
  • Mr Bill
    • Nov 2011
    • 648
    This is a lcd monitor that uses ccfl bulbs. Popped up on my local craigslist. Seller described it as needing new bulbs but after chatting with him the symptom is a dim display that is barely visible but is bright enough that you don't need a flashlight. It almost looks like 1 bulb out of the normal 4 is lit.
    Sorry for the crappy photo but this is something i have never seen before.
    Re: What would cause a dim display
    If any one of the lamp does not work, the inverter circuits will shutdown.
    Does the brightness control do anything?
    • Mr Bill
      • Nov 2011
      • 648
      Thats what was thinking to bud. I never did ask about the brightness, i did however do an ebay search and sure enough there is another monitor (same make and model) with the exact same symptom. Could the power supply give off a low enough voltage to turn the bulbs on but not all the way on or would the inverter shut down? I don't know how much "wiggle" room there is before the inverter detects a fault.
        What is the make and model, it looks familiar.
        • Mr Bill
          • Nov 2011
          • 648
          dell ST2010
          Here is the link to the ebay auction. You can atleast have a better picture of the symptom.
          http://www.ebay.com/itm/Dell-ST2010-...item35bd3101a1
            I worked on the 23" version with cracked screen, so I cannot really tell exactly what is wrong with one a shown on the E-BAY.
            http://s807.photobucket.com/albums/y...ell%20ST2310F/
            For $10 may be a good deal for learning.
            • Mr Bill
              • Nov 2011
              • 648
              I just thought it was odd the ebay one and the craigslist one both have the exact same symptom. I'm debating whether i want to drive 25 minutes but if i doo i'm deffinatly gonna plug in a few spare bulbs i have laying around to see if they fo the same.
                It will be good to have test lamps for sure.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Most lcd monitor pwm inverter ICs are "all or nothing". Either all the bubls work or none at all.
                  If the power supply voltage is low, the voltage may not be enough to enable the pwm IC VCC pin.
                  --- begin sig file ---
                  --- end sig file ---
                  • Rtech
                    • Jul 2010
                    • 1095
                    Have just had a 19" TV, with a very dim screen,and in the end the T-Con board,was not processing the video inputs to it correctly, and a replacement screen restored full operation,,,first time I had seen this sort of fault.
