Magnavox 42MF521D/37B
  • junktv
    • Nov 2010
    • 3065
    Anyone have a service manual for one of these?
    Trying to see if I can fix this for a friend of the family. Symptoms are a steady flashing power button after it is pushed with no picture or sound. Has the normal bad caps and seems the diodes check out.
    I was able to find the spec sheet for the capxon gf caps so have 1 P12384-ND and 3 P12409-ND for replacements in the cart.
    Re: Magnavox 42MF521D/37B
    Both of those caps are suitable replacements.
    If you have a digital multimeter, you can check if the PSU outputs are in spec - if the caps are bad, they will usually read low.
    No luck finding a service manual on my favourite sites.
    • junktv
      • Nov 2010
      • 3065
      I looked also and this board isn't labeled for + and gnd.
        Can you post a pic of around the connector going to the main board, and going to the inverter?
        • retiredcaps
          • Apr 2010
          • 9271
          This power board probably has the same suspect diodes 6054, 6055, and 6056 as the Philips models.
          --- begin sig file ---
          --- end sig file ---
          • junktv
            • Nov 2010
            • 3065
            All diodes seem to read one way but some do climb. Those you listed are 500-600 and steady.
            The frame does have a LG.Phillips sticker.
            • junktv
              • Nov 2010
              • 3065
              Just checking for a manual again incase someone has one that wasn't on last week.
              I have the new caps in now just haven't tried it. To clarify post #6 i tested the diodes still in the board.
              Tom66, I'll get some pics tomorrow before i try it.
              • junktv
                • Nov 2010
                • 3065
                Well i tried it and at first the power button lit up and got bright staying on like it should when working fine but the screen never lit up. I turned it off and realised i forgot to plug in the left inverter. So i unplugged it, let it sit for a bit and plugged in the inverter to try again. This time it acted like it did originally where the power light blinks and won't shut off after being pressed.
                Sorry for the bad pics, all i have is a cell camera.
                  Check you're getting a good +24V going to the inverters.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    As you say pics are not great however can you look near pin 11? on the big transformer
                    there is something doesnt look quite right as though it might be shorting/arcing.
                    • junktv
                      • Nov 2010
                      • 3065
                      Where do i check that? DC?
                      Here are pics of one of the inverters.
                      • junktv
                        • Nov 2010
                        • 3065
                        Yes 11/12 on both plugs are bridged. Looks like it is supposed to be there.
                          DC 200V range. Test the red and black wires. It might be easier to test it at the inverter plug.
                          • junktv
                            • Nov 2010
                            • 3065
                            They were all bouncing from 15-23v except the out side red on wire on the left inverter. It was dead.
                              This indicates a bad startup cap usually - on the primary, a small cap 10uF to 47uF.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                No didnt mean that - see attachments I meant the red circled bit in reflow2
                                In reflow I have marked in red something which looks a bit burnt - is it just the pic.? I have also ringed joints in pink on both that could probably do with
                                re touching but again it could just be the pic.
                                EDIT
                                If the back light doesnt come on at all have you tested the white block fuse on the inverter board.
                                • junktv
                                  • Nov 2010
                                  • 3065
                                  That is flux that was on there and the pic. Some joints did have a bit too much solder and those pics are from before i capped it.
                                  The fuse was the first thing i checked.
                                  • junktv
                                    • Nov 2010
                                    • 3065
                                    Following a test that Plainbill suggested in another thread on one of these i came up with a low voltage and fluctuating readings.
                                    https://www.badcaps.net/forum/showpo...2&postcount=13
                                    DC1 19-23v
                                    DC2 20v
                                    In the 2nd pic it shows the voltage for the inverters. Should i be getting any reading on the middle 2 pins?
                                    I'm not sure what i should be getting on the pinout for the logic board or what is what. The wires alternate red/white/red/white etc so I didn't poke around there.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      Did you miss Tom's post where he said it could be the startup cap?
                                      • junktv
                                        • Nov 2010
                                        • 3065
                                        Woops
                                        I'm guessing it would be near the ic chip and the big cap. There is a 6.8uf and a 100 uf and i'm not sure which it might be. I've actually been trying to scrounge up some from junk i have laying around to test but all i've come up with is new 2.2uf fc's i bought extra of.
                                        • tonybig10
                                          Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                                          by tonybig10
                                          Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                                          the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                                          03-07-2025, 01:03 PM
                                        • slybunda
                                          Gemcon capacitor replacements?
                                          by slybunda
                                          taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
                                          there are 2 caps which im looking to get replacements for.
                                          Branded as Gemcon
                                          single 100uf 16v 6.5mm x 11.5mm
                                          single 100uf 50v 8mm x 11.5mm
                                          lead spacing is around 3mm
                                          there is space for 16mm tall caps
                                          rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
                                          the caps have...
                                          02-05-2024, 03:36 PM
                                        • burom
                                          Xbox 360 Xenon Modern Capacitor Replacements
                                          by burom
                                          I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                                          I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                                          06-07-2024, 05:10 PM
                                        • ziplock
                                          Abit BE6-II motherboard
                                          by ziplock
                                          Greetings,
                                          I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
                                          I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
                                          04-20-2025, 02:09 PM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
