i was trying to figure out if these silver polymer caps with red writing were any good. actually they can be fujitsu which you identify by the first letter on the top line which is an F.
the pic above is the Asus A8R32-MVP which appears to have these caps and also has panasonic and chemicon. no bad brands which is good to see on an asus.
here is a closer view of one of the caps
you can see both the well known yellow fujitsu fpcap re series OL, SL with the cap we are talking about from the same series but R5 type
the specs are ESR 5mOhm, ripple is also high like most polymers
compare them to SEPC which are slightly worse in ESR and max Ripple
the asus board also came with sepc and the rest chemicon instead in some reviews. hmmm tough choice now.
while we are on the subject of polymers, check also the skywell uni-con SEL series above. Their 330uf 16v are often on asus graphics cards. check the specs - bingo they are 7 mOhm ESR and 6100 ripple. the rest of the series is quite strange specs though, not very good at all except for the 820uf 2.5v
