polymer caps with red writing = fujitsu
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    i was trying to figure out if these silver polymer caps with red writing were any good. actually they can be fujitsu which you identify by the first letter on the top line which is an F.
    the pic above is the Asus A8R32-MVP which appears to have these caps and also has panasonic and chemicon. no bad brands which is good to see on an asus.
    here is a closer view of one of the caps
    you can see both the well known yellow fujitsu fpcap re series OL, SL with the cap we are talking about from the same series but R5 type
    the specs are ESR 5mOhm, ripple is also high like most polymers
    compare them to SEPC which are slightly worse in ESR and max Ripple
    the asus board also came with sepc and the rest chemicon instead in some reviews. hmmm tough choice now.
    while we are on the subject of polymers, check also the skywell uni-con SEL series above. Their 330uf 16v are often on asus graphics cards. check the specs - bingo they are 7 mOhm ESR and 6100 ripple. the rest of the series is quite strange specs though, not very good at all except for the 820uf 2.5v
  • linuxguru
    • Apr 2005
    • 1564
    Re: polymer caps with red writing = fujitsu
    The leakage current is awfully high on the Skywells, compared to the Fujitsus.
    Speaking of the Fujitsus, I have a flaky i845PESV with seven yellow Fujitsu 560uF, 4v SPAs - and 3 of them have a small, but unmistakeable bulge on the top. Two of these are on locations right next to 10mm Rubycon 3300uF, 6.3v MBZ - which are absolutely flat-topped. These two locations have both 10mm & 8 mm footprints, which leads me to think that they were originally designed for standard low-ESR Al- electrolytics, but they got swapped out for Fujitsu SPAs when high-power Northwoods came along. The board was brand new, and lasted barely 6 months of normal daily use. Fortunately, the CPU and DDR DIMM survived without harm - I took it out of service the moment it started acting flaky.
    • Tom41
      • Oct 2005
      • 336
      • England
      From what I understand, polymer caps don't have the bulging/leaking problem like electrolytic ones. By this logic, any solid polymers should be 'good' caps... unless they use shoddy manufacturing techniques, that is!
      Also, I just want to point out something. Just because caps don't have a plastic sleeve doesn't necessarily mean they're solid polymer. If you look closely there may well be a K or X vent on the top - and that means electrolytic.
      You know there's something wrong when you open your PC and it has vented Rubycons...
      • linuxguru
        • Apr 2005
        • 1564
        The yellow Fujitsu Solid Polymer Aluminium (SPA) caps all have K-vents, but they're solid electrolyte, not liquid. They've been known to fail due to moisture ingress, sometimes with a small bulge at the top.
        • Chris1992
          • Apr 2005
          • 561
          Like on my Dell Dimension board. It has a few bulged Fujitsu caps, but is perfectly stable.
          The great capacitor showdown!
            Fujitsu LIFEBOOK T726 Hybrid (2-in-1) T Specification for Upgrade or Repair
            This specification for the Fujitsu LIFEBOOK T726 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T726 boardview and T726 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu...
            09-06-2024, 05:40 AM
