Top 5" of Screen is Copied at Bottom
  • tzero11
    • Aug 2011
    • 4
    I have a Philips plasma 42PF7220A/37 that displays fine for most scenes but when the top part of the screen is light and the lower part of the screen is dark, the top 5" of whats displayed on the screen overlays the true image on the bottom of the screen. I call is "ghosting" since I can still see the original image beneath the overlaid image. It is a stationary bar that appears as a "gray" version of whats displayed at the top of the screen. It happens whether the unit is hot or cold and it doesn't matter which input is being used. Specifically, I'm using the HDMI input from my Verizon FIOS STB set to 1080i and the Component input from a DVD player. I've searched around but i can't find anyone else with the same problem or a solution to anything remotely similar.
    I got the TV from my friend who was throwing it because it has the 7-blink error. I ended up changing the y-buffers, changing (2) 3300uf caps on the power supply and replacing a shorted MOSFET on the y-sus board. This is my first plasma repair but I have experience in repairing electronic devices. Please let me know if anyone has a solution.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Top 5" of Screen is Copied at Bottom
    My guess would be the logic main board.
    PlainBill
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • DrvLikHell
      Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
      by DrvLikHell
      Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
      The...
      02-05-2025, 01:44 AM
    • speedtime07
      i life zed air cx5 no image on screen
      by speedtime07
      hi everyone ,
      There is an image on the external computer screen ,
      flexi cable test ok - screen test ok -
      What alternative should I look for?
      thank you for your support​
      04-10-2025, 06:24 AM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
