Sanyo OS-CON SEPC 100uf 16v replacement
  • burningforce
    • May 2011
    • 5
    hello
    I mistakenly broke off a cap off my motherboard and am wanting to find out if it would be cheaper to buy a new one or just replace the cap.
    I will attach a pic of the cap to show you what I need. But I am having a hard time trying to find a replacement for the broken cap. I see badcaps sells some os-con but not in the ranges I need. Could someone tell me were I can get the cap I need or an alternative to it?
    The cap was on the motherboard to the left of the PCI-E x16 slot toward the bottom if that matters
    thanks for the help
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Sanyo OS-CON SEPC 100uf 16v replacement
    SEPC series has two can sizes of 100uF 16v so without the dimensions I can't look up the specs.
    They are both 6.3mm diameter but one is 6mm long and the other 9mm.
    The specs are significantly different.
    Mann-Made Global Warming.
    - Dr Seuss
    • mockingbird
      • Dec 2008
      • 5484
      That's got to be the 9mm long one, just look at the pic.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Looks rather cubic to me.
        If I could tell I wouldn't have asked.
        - Dr Seuss
        • burningforce
          • May 2011
          • 5
          the can itself is 4mm-5mm long, but it has no leads(legs) attached to it so I can not measure it.
          I can take another pic with the cap on its side with a ruler if that would help
          • mockingbird
            • Dec 2008
            • 5484
            Oops, my mistake then.
            Looking at the SEPC spec sheet:
            These are a good match.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              The leads are not part of the measurement.
              That match works.
              You don't have your location entered in you profile so I dunno where to send you.
              If you are in the US you can check digikey.com and mouser.com.
              By what the data sheet shows you need,
              ESR at .024 ohms or less (The Nichicon's 0.025 ohms is close enough)
              Ripple at 2490 mA or less
              - Dr Seuss
              • burningforce
                • May 2011
                • 5
                sorry about that, I live in Illinois - United States
                i checked mouser and digikey and they did not return any results. I do not mind paying a little more to ship from overseas, just trying to keep the costs down.
                thank you both for the help
                • mockingbird
                  • Dec 2008
                  • 5484
                  Shipping is only $2, so you will get four of them and it will cost you $7.
                  Digikey has the PSA listed, but no stock.
                  Mouser has nothing suitable.
                  This guy is your best bet. (They're UCC BTW, not Nichicon. UCC sometimes calls themselves Nippon Chemicon a.k.a NCC)
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    http://www.mouser.com/ProductDetail/...8vwxMySA%3d%3d
                    - Dr Seuss
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Those are 0.08! Way lower, no?
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Typo...... Ripple at 2490 mA or MORE,,, not less..
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Try reading the correct column.
                          https://cdn.badcaps-static.com/pdfs/...fd1de1303c.pdf
                          - Dr Seuss
                          • mockingbird
                            • Dec 2008
                            • 5484
                            Yes, you are correct sir. 0.24. An exact match.
                            But shipping itself is $6.95 (USPS), the eBay guy is still cheaper and he gives him 4 of them. But the product will arrive a lot faster with Mouser.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              0.024
                              Yes but he'll get the caps in 2 or 3 days instead of 2 or 3 weeks.
                              - Dr Seuss
                              • burningforce
                                • May 2011
                                • 5
                                thanks for the links and help PCBONEZ and Mockingbird
                                Will get those ordered asap
                                • reformatt
                                  Macbook Air M2 A2681 Kernel panics after screen replacement
                                  by reformatt
                                  Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                                  It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                                  07-31-2025, 08:37 PM
                                • the_rem
                                  Unknown transformer : how to find a good replacement part ?
                                  by the_rem
                                  Hello guys,
                                  I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                  I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                  04-23-2025, 01:48 AM
                                • ezenia
                                  PS4 controller left stick potentiometer replacement issue
                                  by ezenia
                                  Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                  So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                  I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                  09-30-2023, 02:19 PM
                                • boosti45
                                  Macbook pro logic board replacement parts quesion
                                  by boosti45
                                  i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                  08-21-2024, 05:23 AM
                                • r2digital
                                  klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                                  by r2digital
                                  I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                                  04-18-2024, 03:50 PM
