Hi all, I have an Acer AL2423W LCD monitor that has been plagued with capacitor problems. First, I got the notorious no signal/persistent "ACER" logo problems, which progressed into a flickering screen that would only go away when the monitor had warmed up after a few minutes. So I tore it open to find numerous sorry excuses for capacitors bulging and about to explode (Teapo and Capxon). I replaced all these on the PSU and main logic board with Nichicon and United Chemicon capacitors. After doing so, everything worked fine for a few months.
Unfortunately, I overlooked the lamp inverter, as it was underneath a shield and so I assumed it would be fine and not worth looking at. I regret that now. I got back from a trip to find that the backlight on my monitor would not come on. Tearing it apart again, I found 3 bulging NKCon capacitors on the board (seems like another garbage brand). I replaced these with Chemicoms and reinstalled it. However, the backlight would still not power on. So I checked the fuses, none of them were open. Checked the power, board is getting 19V, per spec.
I assume that the caps took out the MOSFETs with them, as there is no voltage coming from the output side of any of them. It does seem odd though that all six MOSFETs would go out, so I'm thinking it could also be the PWM chip. Any idea which would be the more likely culprit? I could replace the MOSFET chips if I can find an equivalent replacement for them. The PWM chip looks like it would be too much of a pain to bother replacing (has 20 closely-spaced legs). There is also a window comparator chip on there, but I don't think it's a likely candidate.
The inverter board is a TDK model XAD306LR.
The MOSFETs are NIKO-SEM P2804NVG N&P-channel enhancement mode FETs.
Any idea where I could find a replacement/equivalent inverter board, or MOSFET chips, if they are the likely culprit? The monitor has a superb MVA panel, and I'd hate to get rid of it and downgrade to an inferior TN panel. Any help would be greatly appreciated.
