HP Elitebook 840 G5 Endpoint Security Controller Problem
  • filewalker
    • Dec 2020
    • 16
    I have recently bought a Laptop that has a Endpoint Security Controller Problem. According to the seller it has just appeared all of the sudden.
    Things I have tried so far:
    • Restore the security settings to defaults and restart the laptop
    • Disable all the security options
    • Clear the NvramActiveRegn areas (replace with FF) Hex Area 37000-38FF0
    Also I have checked the DMI Information which seems right according to the stickers on the mainboard.
    Is there anything else I can try?
  • hoaca388
    Badcaps
    • Jan 2022
    • 12425
    Re: HP Elitebook 840 G5 Endpoint Security Controller Problem
    EliteBook 840 G5
    • filewalker
      • Dec 2020
      • 16
      Originally posted by hoaca388
      EliteBook 840 G5
      Thank you very much. This worked after setting the DMI Information and MAC address.
      • NaneName
        • Sep 2022
        • 13
        • Russia
        EliteBook 840 G5
        hoaca388, Can I use "840 G5 32MB.rar" on another HP EB 840 G5 with my modified "840 G5 16MB.rar"?
        • niggi
          • May 2016
          • 210
          • UAE
          EliteBook 840 G5
          i have 840 g5 .i remove bios password .after display come and error end point security error plz help me
          • niggi
            • May 2016
            • 210
            • UAE
            what is the setting dmi info or mac addres plzz tell me.
            • hardware1
              • Sep 2021
              • 2949
              • N/A
              Here are your Unlocked files, you should program both chips together, in the first boot go to bios menu and disable security options (Default).
              all donations are welcome,
              • hardware1
                • Sep 2021
                • 2949
                • N/A
                DMI is (Device Manufacturing Information) such as your Serial Number, Model Number, UUID and etc..
                MAC Address is your Network Card or LAN Card address.
                • danito
                  • Jun 2016
                  • 1218
                  • Romania
                  Can you help me too? The same problem, after removing the password it gives me this error.
                  • medinfo
                    • May 2016
                    • 331
                    • Morocco
                    Elitebook 840 G5 (EndPoint Security Controller Problem)
                    HP Elitebook 840 G5 (HP EndPoint Security Controller Problem)
                    please help to fix it
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12425
                      Re: Elitebook 840 G5 (EndPoint Security Controller Problem)
                      Originally posted by medinfo
                      hp elitebook 840 g5 (hp endpoint security controller problem)
                      cccccccc
                      • medinfo
                        • May 2016
                        • 331
                        • Morocco
                        cccccccc
                        only the 32mb ?
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12425
                          HP EliteBook 840 G5 Notebook PC
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12425
                            only the 32mb ?
                            Yes ! only 32MB
                            • medinfo
                              • May 2016
                              • 331
                              • Morocco
                              Yes ! only 32MB
                              but i have NvramActiveRegn on the EC !!
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12425
                                Do you want to fix the EndPoint Security Controller Problem?
                                • medinfo
                                  • May 2016
                                  • 331
                                  • Morocco
                                  yes this is the problem
                                  Do not start !
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12425
                                    Do not start !
                                    Only flash 32MB , Reuse 16MB orginal.
                                    • medinfo
                                      • May 2016
                                      • 331
                                      • Morocco
                                      ok
                                      • medinfo
                                        • May 2016
                                        • 331
                                        • Morocco
                                        worked thank you
                                        • kolebbk
                                          HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                                          by kolebbk
                                          Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                                          HP Endpoint Security Controller problem
                                          there is a problem with the hp endpoint security controller on the unit
                                          I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                                          09-04-2024, 12:44 AM
                                        • fede77
                                          Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                                          by fede77
                                          Notebook HP ProBook 450 G8
                                          ProdID 2K8L1LT#AC8
                                          Mother: DAX8QAMB8D0 REV D
                                          The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                                          03-10-2025, 07:12 AM
                                        • lamonde
                                          850 G6 Endpoint Security Controller Problem
                                          by lamonde
                                          Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
                                          and there is no soud after flashing new bios, may be have some solutions?
                                          ProdID: 4YD62AV
                                          SN: 2TK9500V8X...
                                          01-15-2025, 09:31 AM
                                        • biednybelfer
                                          HP HP MT45 Mobile Thin Client Endpoint Security Controller Problem
                                          by biednybelfer
                                          After removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
                                          Mainbard model:6050A3044201-MB-A01 (A1)​
                                          Serial Number: 5CG0275ZLV
                                          (I'm not allowed to upload files with the extension bin, so I upload zip)...
                                          10-05-2024, 05:04 AM
                                        • Voyager65
                                          HP 800 G6 Deskop Mini - Endpoint Security Controller Problem
                                          by Voyager65
                                          I got a used HP and see this well known HP Endpoint Security Problem Screen. Someone seems to have removed the password and reflashed the bios with (maybe) a wrong serial etc.. I was able to read and write with my programmer a new bios onto it - same problem. I tried a downgrade, same.
                                          I did password removal wir rcunlocker on several other machines without any problem. But this one is/was killed before. Appreciate any help.
                                          SN: 8CC1120Z0V
                                          PN: 8WY18AV
                                          Bios Dump:
                                          Thanks a lot...
                                          01-13-2024, 04:58 PM
