19 inch samsung powers off when VGA plugged in.
  • edharvey
    • Jul 2010
    • 17
    Hi
    I have a 19 inch samsung LCD monitor which turns on ok, with power lights going and no signal message on screen. However as soon as I plug the VGA cable into the monitor, the backlights switch off and the monitor seems to just shut down. I have opened the monitor up and checked the capacitors. Most are Samxon and none of them are bulged. I have removed four of the large samxon capacitors from the low voltage side of the power supply and checked these on an RCL meter, all of them tested ok. Any ideas where to go now?
    Ed
  • retiredcaps
    • Apr 2010
    • 9271
    Re: 19 inch samsung powers off when VGA plugged in.
    Originally posted by edharvey
    Hi
    It would help to know what Samsung model.
    A clear focused set of pictures of all boards (top down, both sides) would help after reading this.
    https://www.badcaps.net/forum/showthread.php?t=1868
    Have you tried more than one source on the VGA port?
    --- begin sig file ---
    --- end sig file ---
    • edharvey
      • Jul 2010
      • 17
      Hi
      The model is a SyncMaster 913V 19inch
      Here are some photos, the capacitors circled with green are all Samxon brand and have been checked.
      There is nothing wrong with the PC that I plugged into the monitor either, it has been used with many other monitors just fine.
      Thanks again
      Ed
      • edharvey
        • Jul 2010
        • 17
        Forgot to post pictures of the back, sorry about the quality, my cameras not great..
        Nothing much to see on the back of the logic board, no components and all solder joints are clean etc
        • hoadle
          • Jul 2010
          • 174
          Can you clear for my on second picture at righthand corner had burned mark?
          If so the VGA board is bad, had short to ground when you plug VGA cable & shut off monitor.
          • mockingbird
            • Dec 2008
            • 5484
            You see the chip that says SE7889-LF?
            It is defective. There is no way to fix this monitor. Even if you replace the caps.
            • edharvey
              • Jul 2010
              • 17
              Thanks for the reply's, The top of the board does look like it is burnt in the photo however it is actually fine. Is it still likely that the chip is defective though?
              • seanc
                • Nov 2008
                • 1319
                You could replace the chip though.
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  Read this article. Same exact problem - solution is what mockingbird said.
                  http://ezinearticles.com/?Samsung-71...blem&id=458167
                  This will be hard for a novice to replace. There is one chip being sold on ebay (ebay item number: 250646876175). That is, if you dare to try. But then again, the chip is being sold for $20. Is it worth $20 to fix this monitor?? MAYBE - Then again, it is a samsung!
                  • edharvey
                    • Jul 2010
                    • 17
                    Ok, thanks for all your messages guys. When I get home I will have a look at the board and make a call from then. I have a pretty decent soldering iron and have done quite a lot of soldering but I'm not sure if that will suffice!
                    Thanks again
                    Ed
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
