Hi, that card in 3 diferent computers is only detected as a generic display driver, have nothing to do with drivers, post fine but not detected as a gtx, any clue? thanks
GTX 760 not recogniced correctly
Re: GTX 760 not recogniced correctly
Hi, finally it was a memmory fault as ktmmotocross said, thanks a lot.
But the problem was a faulty capacitor near the memmory module that was giving errors, so no need to work on the module, just replace the capacitor
Graphic card working again, thanks a lotComment
Well, I had a look in the directions where KTMmotocross told me, memmory problem, used MATS, it detected some (14K) faults, had a look with the microscope arround the faulty mem, saw a discolored capacitor and why not meassuring it???, looks like faulty? change it!!!, no heat aplied to the mem chip, so it seems to be just that capacitor out of range, now everything is running fine, detected as it is and GPU-Z tells its fine. Changed pads and thermal paste, runned furmark for an hour and still fine. Card is working and doing what it has to do, play games.
Thanks to KTM user and all of the comunityComment
by EvazXHello everyone,
I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
However, after some time, the replacement motherboard...08-25-2025, 06:09 PM -
by DynaxSCHi,
I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
The behaviour is also really very strange, i.e.:- The disk shows always up in BIOS - so it is recognized, so far so good
- POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
by spacezI have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
Service Tag: J2MSHW3
|Express Service Code: 41518077843
mother board LA-L402P REV 1.0(A00)...-
Channel: BIOS Requests ONLY!
by Nikan.eGreetings and Salutations!
I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
The faulty DrMOS was removed, and the burned PCB area was milled away.
All voltages are now good, but the GPU is not being detected.
I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
I thought these pins were used for communication during startup?!?
On all...03-30-2025, 07:21 AM -
by superdota2HP 15s-FQ2552TU
da0p5hmb8f1 rev f
sn# 5CD138CCH4
problem is power on but no display,no bios post
i search bios here ,i found and it work and got display.
https://www.badcaps.net/forum/showthread.php?t=104925
second problem is nvme drive not detected in bios intel rapid storage,
i tried a working nvme drive but still not detected in bios,
also tried install system and install intel rapid driver,still not detected....-
- Loading...
- No more items.
