HP 250 G5: shutdown after 4-5 seconds
  • DrFalken
    • May 2008
    • 122
    Hello !
    model: HP 250 G5 W4N09EA
    motherboard: BDL50 LA-D703P
    This laptop turn on, fan spin and then shutdown after 4-5 seconds, no signal on monitor.
    I've already changed PSU and flashed BIOS.
    Light in DC socket is solid white.
    PJP1: 19.53V
    When ON:
    BIOS PIN 8: 3.35V, 20 Ohm (to GND)
    PL202: 2.90V
    PL14: 1.69V near PCZ42, 0.3V rapidly drop to 0 the other side
    PC78: 19.53V
    PL8: 5.08V
    PL9: 3.35V
    PL11: 1.35V
    What can I check ?
    Thank you !!
  • mayss
    • Nov 2016
    • 30
    • Polska
    Re: HP 250 G5: shutdown after 4-5 seconds
    Program the bios with specified file with the ME-Region cleared and describe motherboard reaction. Without a battery RTC should rum off/on approximately 3 times before the image appears on the screen.
    Last edited by SMDFlea; 11-16-2021, 09:53 AM. Reason: Not bios requests section.Bios removed
    • DrFalken
      • May 2008
      • 122
      BIOS flashed but has the same issue.
      Turn on, fan spin for 4-5 seconds then switch off and nothing more
      • lapfix
        • Mar 2020
        • 2741
        • my workshop
        Hope that you clean me your dump with official tool....do you have schematic/Brd of this motherboard !
        • DrFalken
          • May 2008
          • 122
          I've flashed the bios provided by mayss
          Attached the schematic of this board.
          Can't find anywhere boardview of this MB
          • lapfix
            • Mar 2020
            • 2741
            • my workshop
            Post your old dump please : https://www.badcaps.net/forum/forumdisplay.php?f=40
            • DrFalken
              • May 2008
              • 122
              Shoud I open a new thread there or can I post it here ?
              • lapfix
                • Mar 2020
                • 2741
                • my workshop
                new thread asking for clear pwd
                • DrFalken
                  • May 2008
                  • 122
                  Ok, done https://www.badcaps.net/forum/showthread.php?t=100961
                  Edit: thank you, flashed the bios with ME cleaned but nothing has changed (fan spin for 4-5 sec. then shutdown, no signal)
                  • DrFalken
                    • May 2008
                    • 122
                    Tried both lapfix and SMDFlea BIOS on that thread but nothing has changed.
                    FIY same behaviour show up also if I completely remove the BIOS chip (fan turn on but shutdown after 4-5 seconds)
                    • m.tech
                      • Aug 2024
                      • 25
                      • Italy
                      I have a very similar problem with the G8 model. How did you solve it? Thanks​
                      • sew333
                        Pc shutdown, monitor flickered with no signal after 10 seconds
                        by sew333
                        My pc:
                        10850K stock 4800mhz stock Kraken X73 good temps
                        2x16 GB DDR4 GSKILL 3000mhz XMP
                        Seasonic Tx-850 Ultra Titanium
                        Gigabyte Rtx 3090 Gaming OC
                        Aorus Z490 Pro Gaming
                        1 TB SSD
                        4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                        Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                        Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                        Power...
                        02-22-2022, 10:27 AM
                      • DrFalken
                        Dell Inspiron 5593 shutdown after 5 seconds
                        by DrFalken
                        Hello everyone!
                        Motherboard model: FDI55 LA-J081P
                        Today a customer delivered this laptop completely dead, with the original power supply shorting when plugged into the connector.
                        I found and replaced a shorted MOSFET (PQZ3).
                        Now the laptop turns on (fan runs fine but no video signal) and after 5 seconds it turns off.
                        BIOS has already been updated (both 64MB and 128MB IC)
                        +3VALW and +5VALW are still present.
                        +VCCIN = 1.8V stable (measured on PLZ1 at power up)
                        Abnormal readings:
                        PLZ1 to GND = 0 Ohm
                        PLZ2 to GND = 0 Ohm
                        04-09-2025, 10:45 AM
                      • rex98
                        Msi b250m bazooka shutdown after few seconds
                        by rex98
                        Does anyone here encountered the same problem i have on this motherboard? It shutdown after few seconds PCH is hot. The bios is fine. All voltage signals are normal it just shutsdown when it turned on a few seconds like 30sec the logo shows up ang bios settings shows the pch heats up then shutsdown itself. Can someone help me. I need schematics and boardview of this motherboard....
                        04-09-2023, 09:27 PM
                      • Pygo86
                        Liyama G-Master GB3466WQSU-B1 - Backlight on - Shutdown after a few Seconds
                        by Pygo86
                        Hey Folks,
                        i'm not far into Monitor troubleshooting. It's my first time. Normaly i try to repair Laptops.
                        The Monitor is powering up. And the Backlight turns on. After a few Seconds the Backlight shuts off and the Power LED turns form Blue to Red.
                        I can power it up again, but it's always the same Result.
                        No Matter which Connection is used.
                        I can't see anything obvius after disassembling. No Heatspots with the Thermalcam visible.
                        The Powerboard is looking great. There is 12V and 5V everywhere on the Logicboard.
                        So, i decided to swap that Logicboard....
                        03-04-2024, 11:38 AM
                      • johnbeton
                        Aspire A315-56 LA-J801P shutdown after 4 seconds
                        by johnbeton
                        I have a Aspire A315-56 with a LA-J801P mainboard.
                        After liquid damage, the system did not power on at all. After replacing PR509 (499K Ohm - ENLDO_5V) the powerled goes on for 4 seconds, then shutsoff. No image.
                        Anyone an idea what to check next ?
                        Thanks in advance
                        05-08-2023, 01:33 PM
