2sd high side mosfet was shorted, and replaced. ok.
Now, all is good (I have another exactly same MB working for compare), except a low voltage drop on mosfet of buck converter, close the ram. 0,150v instead 0,450v for working MB.
I removed this mosfet, and no change, the 0,150v stay on the coil pad (ram side).
In following direction of 19v power rail : voltages drops are fines. But in ram direction, at all caps around ram modules, I measuring (of course) the same voltage drop than the coil.
I guess the internal power line of ram modules could be bad ? Do you see another explanation pls ? How to check ?
If I temove the two other mosfet close the coil, ram should be fully isolate from power lines ? And if voltage drop is the same, that means the ram internal power lines are broken ?
I worked only without power, maybe the MB works. But I'm scared to try wuth this issue.
