Hello everyone, I think I am the worst repair guy here is my story...
I am trying to repair my daughter's board bought 3 months ago she dropped the macbook pro Board 820-01987 Resulting in no Backlight no Image.
I had fan spin and normal voltage and Amps at this point with the board out.
I tried to take some measurement on the display cable.
Unfortunately I felt a quick hot sensation when I did this... I know I know...
This is where I am at:
When I plug in the A2289 I Get 20.4V and takes 0.13A jumping after to 0.36 sometimes 0.42 and go back down to
0.29A Stays Steady for 10 seconds and the dies to 0.0A
Comes back up to 0.16A and then back down to 0.00A and stays there.
The only schematics and boardview I have found is the 820-01598 Which seems to be close enough to the 820-01987
So keep in mind that these can possibly be wrong but I tried my best to be close to the truth.
Here are some measurements...
PBUS G3H 12.62V
PBUS G3H_SSDO 12.62V
PP3V3_G3H_RTC 3.31V
PP3V3_G3H 3.3V
PP1V8_SLPS2R 1.8V
SIG OUT / PMU_CLK32K_SOC 0.85V
PP1V8_AWAKE 1.8V
PP1V8_SLPS2R_PMUGPIO 1.8V
PP1V1_SLPS2R 1.1V
PP0V8_SLPS2R 0.79V
PP0V82_SLPDDR 0.77V
PP3V3_AWAKE 3.3V
PPVDDCPUSRAM_AWAKE 0.8V
PP0V9_SLPDDR 0.9V
PP1V1_SLPDDR 1.1V
PP1V2_AWAKE 1.2V
PPVDDCPU_AWAKE 0.53V
PP3V_G3H_RTC 3.01V
PP5V_G3S 5.12V (ON C3111)
PP3V3_G3S 3.31V
PP1V8_G3S 1.8V
P5VG3S_PGOOD 1.25V
PPVCCQ_ANI_SSD0 1.8V
PP0V9_SSD0 0.89V
PP2V5_NAND_SSD0 2.52V
PMU_ONOFF_L 1.78V
PP3V3_S5 3.3 V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 2.40V WITH 0 AMPS TAKEN
PP1V8_S5 1.80V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.2V WITH 0 AMPS TAKEN
PPVPCORE_S5 1.04V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
PP1V_PRIM 1.04V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
PP1V8_S3 ?
PP1V2_S3 1.2V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
PP1V_S3 1.04V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
PP1V2_S0SW 1.2V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN THIS TIME BOARD WENT UP TO 0.50AMP WITH PROBE ON IT
PP1V_S0SW 1.04V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
PPVCCIO 0.98V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
PPVCC_S0_CPU 0.03V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN Resistance 2.5ohms to Ground Diode 0.005
PPVCCSA_S0_CPU 0.00V
PPVCCGT_S0_CPU 0.00V
U7210 Appears to have all in lines...but
L7210 0.00v pin 1 and 2
L7220 0.00v pin 1 and 2
L7270 0.00v pin 1 and 2
L7410 0.00v pin 1 and 2
L7420 0.00v pin 1 and 2
Rip CPU ?
Thank you for your kind responses and help I am lost at this point.
PBUS G3H 12.62V
PP3V3_G3H_RTC 3.31V
PP3V3_G3H 3.3V
PP1V8_SLPS2R 1.8V
PP1V8_AWAKE 1.8V
PP1V1_SLPS2R 1.1V
PP0V8_SLPS2R 0.79V
PP0V82_SLPDDR 0.77V
PP3V3_AWAKE 3.3V
PP0V9_SLPDDR 0.9V
PP1V1_SLPDDR 1.1V
PP1V2_AWAKE 1.2V
PP3V_G3H_RTC 3.01V
PP3V3_G3S 3.31V
PP1V8_G3S 1.8V
P5VG3S_PGOOD 1.25V
PP0V9_SSD0 0.89V
PMU_ONOFF_L 1.78V
PP1V8_S3 ?
Rip CPU ?
