Anyone repaired the PSU in one of these and if so is there anything I should be checking before powering it back up again?
I've replaced all of the failed capacitors including the Rubycon ZLH's and I came across some odd schottky diodes with very high reverse leakage current Sanken "RA13" which had me stumped for a bit.
Nearly all the capacitors on the PSU tested bad but not all had visible signs, one day it just failed to even enter standby. Is replacing the capacitors all there is to getting these back up and running again or are there other things that fail once the multiple voltage rails have been messed around by bad caps? The Sky viewing card slot went a bit finicky in the weeks leading up to it failing too.
Thanks.
Thanks.
